Gresen 2712 Control Valve power beyond?
   / Gresen 2712 Control Valve power beyond? #1
MNBobcat
Platinum Member
I have a 2-spool Gresen 2712 control valve on my JD3020 front-end loader. Does anyone know if that valve has power beyond? I need to add another control lever and don't want to swap out the whole valve if I don't have to.
I can't find any documentation on this valve and nothing in google either.
Thanks!
   / Gresen 2712 Control Valve power beyond? #2
Look at your valve and see if it has 7 hoses. Also look for letters stamped on the valve such as P,T.PB, PBYD, A,B.
Perhaps some pictures of the valve would help with ID.
JJ,
It does have the letter "Y" stamped on it. I'll have to go count the hoses a bit later. Can maybe get a photo then, too.
Thanks for the reply!
   / Gresen 2712 Control Valve power beyond? #4
A follow on. The valve may only have 6 hoses, but still have a plug where a PB outlet is located. If so, the PB add on will consist of a hex screw that would screw inside the port, or have a long sleeve adapter that will separate the OUT and downstream flow.
Here are the photos
   / Gresen 2712 Control Valve power beyond? #6
Yes it does have PB port. It's the hex screw in picture #3 right behind the out hose.
I thought that might be it. Its starting to look like by the time I order a power beyond kit and buy another control and a tee for the return line, that I may not save any money over buying a new 3-spool control.
I was hoping not to spend upwards of $300. Can't find a used one locally.
I built a skid steer adapter for my tractor and only have $75 in it. Did good up until the hydraulics!
   / Gresen 2712 Control Valve power beyond? #8
Did you want 3 levers spool valve or joystick valve like this.
Surplus Center - 2 SPOOL 25 GPM JOYSTICK LOADER CONTROL VALVE
Just how much for a PB sleeve for your valve?
A Prince PB sleeve is only about $15
If you get another valve, it will also need PB if connected in series.
I would install a new joystick valve and use the 3 lever as a remote setup. You have everything you need except for the PB sleeve, and a bunch of QD's.
   / Gresen 2712 Control Valve power beyond? #9
Yes it's the perfect time to upgrade to a joystick loader control (I'd also get it with available PBYD, most are anyway). Use your current valve and have 2 remotes instead of one.
I need to operate lift, tilt and clamping action of my root grapple. So essentially 3 different hydraulic circuits.
The joystick would be very handy for lift and tilt.
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
20ft Driveway Entrance Gate with 2 Columns (A57454)
20ft Driveway...
2018 FREIGHTLINER CASCADIA SLEEPER (A59575)
2018 FREIGHTLINER...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
Topsoil Trommel (A57453)
Topsoil Trommel...
Miscellaneous Tech and Electronics (A56860)
Miscellaneous Tech...
