Ground PSI
   / Ground PSI #11
Many of these tires have a pressure of 22 psi, but that seems two high for a ground pressure. Am I missing something.
It may be max pressure rating for the tire, not the recommended inflation pressure for that tire on the mower. Some of my mowers have spec'd as little as 10psi for the rear tires, which is well below what the tire can handle.
   / Ground PSI #15
Agree with ArlyA, and didn't see any part of the video's that showed it on a finished lawn doing a "zero turn" which most certainly will leave a scuff mark.
   / Ground PSI #16
a wheeled ZT would make a bigger scuff mark!.. there's MUCH less PSI on a tracked ZT..
   / Ground PSI #17
I’m guessing you don’t have a lot or probably any experience running tracked machines. That thing is going to rip up any grass and if the soil was soft enough to actually need that you can count on the grass being pretty much destroyed trying to turn.
   / Ground PSI #18
You can see one turn at :53 into the video. It's a wide turn and you can see it slightly damaged the turf. It's highly suspicious as to why they didn't show a "zero turn" mower executing a zero turn maneuver. :(
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
