GT2542 Hydro problem
/ GT2542 Hydro problem #1
zeke83
Little falls, NY
Cub Cadet GT2542
I just got a used GT2542 with 280 hrs...Thanks to snooping around this forum before I registered
I did a full service including replacing the hydro fluid and filter. I drained the fluid and replaced the filter, then I added 5 quarts of 15-40 rotella T. The dip stick said it was full, so I started the engine to circulate the oil and get a better reading. The problem is the tractor wont move now. When I press the forward or reverse nothing happens at all.
One thing I noticed is the lever to engage and disengage the transmission is not there...Must be it fell off on the previous owner??
Any help??
Doing a search here with some better keywords has me to believe that my problem is using an aftermarket filter.
/ GT2542 Hydro problem #3
That or it might just need to be bleed. Get the wheels up off the ground and try going forward and reverse with it off the ground.
It's been a year, what did you end up finding out on it ??
