Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #21
I know I must take a toll on the wet and dry clutches of my GST L39 when plowing snow, forward and reverse at load and up to 2200 RPM, over and over again and again.
Respectfully I am not sure that is the case. I have a 11,000 pound John Deere 350D bulldozer with hydraulic reverser and it is 30 years old. A bulldozer by design is to run at full throttle, and shuttle back and forth without stopping, it even says so numerous times in the service manual. My bulldozer has its original reverser clutches and so far has only needed a hydraulic oil filter changed on it and runs perfectly fine.
The two most detrimental factors for hydraulic clutches in my opinion are dirty oil and heat. The clutches themselves are designed to take the enormous load.
Myself, and I know this happens on a farm, I think the hired hand is bored and needed something to discuss. It is all in good fun, but I think the clutch wear is being over analyzed. The only pto attachment I throttle down before shut down is my pto generator, BUT even then I am not sure with a PTO over-running clutch on it, that it really matters.
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #22
The JD 350 and JD450 are sure are great little dozers. Many a basement were dug and many sites cleared with them prior to everyone using excavators.
I believe the Hydraulic wet clutches are designed to last a long time. Also the dry clutch if used properly in Power Reverser type transmissions will see less use than a gear transmission, therefore if similarly sized compared to a gear unit, should last longer also.
I still feel guilty not being easier on my GST tractor when I snow plow for the sake of "Get er Done" When I'm in a barn or arena with my little Max28 dry clutch Shuttle. I move around at near idle.
Even if a utility tractor is used for mainly field work, where a straight gear tractor is just fine, the tractor would be far more versatile if purchased with a Power Reverser transmission, along with being much nicer to operate. Case in point; the subject of this thread.
My seat time on straight gear tractors has been mainly my old B7200D and a JD790. I'm a gear guy, but I liked the tractors more than their transmissions.
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #23
When I was about 12 years old I went with my dad to a farm show. They had a clutch installed in a plexiglass case and with a load on the engine at high RPM they would engage the clutch. A big ball of fire would shoot off of the clutch! When they would idle down, then clutch, not even a hint of heat could be seen. It was cool as a kid to see and always has stuck with me. From that day forward I always idle down to clutch. So far in life, knock on wood, I have had very good luck with clutches. Wish I had that on video.
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #24
Sounds about right. As far as dozer wet clutches, they are designed to take full rpm clutching, something a tractor (particularly dry clutch) is not able to tolerate.
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #25
I think we are in full agreement on this.
You are right though that the bulldozer analogy should probably be taken off the table as they are their own entity really. Dedicated transmission pump for positive pressure, dedicated transmission filter for clean oil, etc...that makes for a different animal for sure.
One of the reasons I use my bulldozer to plow snow is because of its reverser. I could use my Kubota, but being a gear drive, constantly clutching is hard on it, and a pain for me. (Obviously the dozers 8 foot, 6 way blade also plays a role).
Please accept my apologies for bringing in the John Deere 350 dozer into the thread; in reflection it was out of context.
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #26
One day I am going to build my own perfect tractor. I have operated many, many tractors and while I like them all, none are perfect in my opinion.
Tracks
Duel transmissions (1 automatic)
Hydraulic reverser
PTO
3 Point Hitch
Tracks (of course)
Decelerator pedal (where have they been on tractors for say...the past 100 years?)
Loader (4 way)
It is quite a bucket list, but I want to build one someday.
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #27
Ask the clutch slipping worker to search clutch replacement procedure pictures. Does he understand "splitting" a tractor?
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #28
Clutch slipping worker that sets hand throttle needs to be shown unemployment line. Tractor has foot throttle. Disconnect hand throttle unless you do PTO work.
Clutch to be engaged at lowest RPM possible.
I have NEVER had to set the hand throttle to pull away on flat hard ground with a loaded 4 wheel wagon in high range 1st in any tractor I've driven.
I haven't driven a 5055D, but drove a 5055E, so 9x3 instead of the 8x4. Could pull away in C1 no throttle towing nothing.
Never drove a crash box that couldn't be shifted on the fly if pulling a rolling load on a hard surface. 5055D is an H shift pattern right?
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #29
My tractor痴 owner痴 manual instructs to set the engine at medium speed with the hand throttle then release the clutch. Except for indicating that it has a foot throttle, it doesn稚 even mention operating the tractor with the foot throttle.
It seems to me that my tractor is specifically designed to be operated with the engine set at operating speed using the hand throttle. I think saying someone should be shown the unemployment line for operating the tractor in this fashion is a little extreme.
There are a lot of tractors that don稚 have foot throttles and that do have loaders. It would be pretty difficult to do loader work if you have to manually throttle it up and down each time you stopped and changed direction.
   / Hand throttle setting - faster clutch wear? - gears only, no Shuttle Shift #30
Think I will continue using the foot throttle like I always have for forward/reversing, stopping/starting and loader work.
2100 hours , countless forward/reverses and hundreds of tons of loader work and I have yet to need the first clutch adjustment.
Look at a dry clutch for a car, truck and a tractor. Pretty much the same.
Nothing special about a tractor dry clutch.
Slip them they wear out faster, high RPM's while clutching will cause faster wear. Simple as that.
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
