Harbor Freight 3-point quick hitch
   / Harbor Freight 3-point quick hitch #51
I think its the vertical distance between the lift hooks and the top hook on the quick hitch. The top hook can be adjusted up and down to accomodated differences between implements.
larry
   / Harbor Freight 3-point quick hitch #52
</font><font color="blue" class="small">( I checked the other day, mine is backordered )</font>
Mine is as well. HF sent a postcard confirming my order though.
   / Harbor Freight 3-point quick hitch #53
   / Harbor Freight 3-point quick hitch #54
Got it. Thanks.
Anyone else having problems fitting the hitch over the lift arm balls?
I just measured my hitch and it is darn near 1 3/8 inch. Or as close as I could get eyeballing it
   / Harbor Freight 3-point quick hitch #55
Got it. Thanks.
   / Harbor Freight 3-point quick hitch #56
</font><font color="blue" class="small">( Got it. Thanks.
I just measured my hitch and it is darn near 1 3/8 inch. Or as close as I could get eyeballing it )</font>
I've had this problem on a couple of other devices, a couple minutes with a grinder or belt sander and it'll fit just fine. /forums/images/graemlins/wink.gif
   / Harbor Freight 3-point quick hitch #57
   / Harbor Freight 3-point quick hitch #58
</font><font color="blue" class="small">( I've had this problem on a couple of other devices, a couple minutes with a grinder or belt sander and it'll fit just fine. /forums/images/graemlins/wink.gif )</font>
Not to sound totally ignorant, but I think you are confirming the fitment issue solution. Earlier there was mention of cutting, widening and re-welding the QH frame itself, which sounded rather drastic. I'm going on the assumption all one simply needs to do is grind 1/16' off each outer side edge of each lift arm swivel ball for the HF Quick Hitch to slide onto the lift arms. I.e., the male part is too big for the female part. /forums/images/graemlins/blush.gif Or am I missing something.?
   / Harbor Freight 3-point quick hitch #59
   / Harbor Freight 3-point quick hitch #60
dholly. Grinding the lift balls would work. This will allow less ball swivel than was originally provided. Im just not willing to modify my tractor to fit the implement - particularly when the mod would compromise the tractor rather than improving it.
Larry
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
(APPROX 40) 1 1/2" X 1 1/2" X 74" TUBING (A57192)
(APPROX 40) 1 1/2"...
2014 Ford Fusion SE Hatchback (A55853)
2014 Ford Fusion...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A57193)
UNUSED LANDHERO...
