Harbor Freight Metal Cut off Saw - Opinions?
   / Harbor Freight Metal Cut off Saw - Opinions? #31
Would there be any reason a chop blade couldn't be put on a power mitre saw just for occasional use with smaller stock?
   / Harbor Freight Metal Cut off Saw - Opinions? #32
</font><font color="blue" class="small">( Would there be any reason a chop blade couldn't be put on a power mitre saw just for occasional use with smaller stock? )</font>
It will work. HOWEVER /forums/images/graemlins/smile.gif
If you want to keep iron particals from staining the wood you're working on, you'll need to carefully clean the chopsaw when switching back to the wood blade. Also, the wood miter saws don't have the built in clamp to hold the workpeice, so you pretty much need welding gloves (or a high tolerance of pain) to make cuts this way.
These are the main reason's I'm looking getting a dedicate machine to do this. That, and it's a big pain to switch back and forth.
   / Harbor Freight Metal Cut off Saw - Opinions? #33
Either saw will last a long time if you don't bog the motor down. Bog it down, it gets hot and melts something. Let the blade spin free, be patient, and you'll get 3x your money's worth.
Generac Generator (A51691)
Generac Generator...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
378812 (A51573)
378812 (A51573)
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
20702 (A51694)
20702 (A51694)
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
