Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #10,951
So are you trying to open it without damaging the safe?
   / Harbor Freight Tools that don't suck #10,952
Whatç—´ your thoughts on the rotary hammers?
Been wanting one for a while. Main task will be concrete drilling and driving ground rods. New harbor freight opened about 30 miles away. So far itç—´ the closest and weæ±*e in the city weekly. Thinking about the 1 1/8 $97 one. Thereç—´ also a 1 $82 one. Next step is 1 9/16 for $150.
For what you want, I definitely would not go lighter than the 1-9/16" SDS Max. 1.5 Amp 1-9/16 in. SDS Max-Type Pro Variable Speed Rotary Hammer Kit
   / Harbor Freight Tools that don't suck #10,953
For what you want, I definitely would not go lighter than the 10.5A 1-9/16" SDS Max. 1.5 Amp 1-9/16 in. SDS Max-Type Pro Variable Speed Rotary Hammer Kit
I've had the blue predecessor of this model for four or five years and like it a lot. Good combination of power and weight.
   / Harbor Freight Tools that don't suck #10,954
   / Harbor Freight Tools that don't suck #10,955
   / Harbor Freight Tools that don't suck #10,956
The SDS max is a heavier duty drill. That’s the size of bits it uses. I’ve got one and I’ve never tried but I believe it would drive ground rods. It’s the best thing ever for drilling holes and knocking off masonry products inside.
   / Harbor Freight Tools that don't suck #10,957
I’m curious as to how well rotary hammers work driving ground rods?
I’ll be installing some temporary electric fence in the spring in several places as we replace some cross fencing.
I have always drove ground rods with a post driver and then a sledge near the ground. My understanding is they work very well. But you just use the hammer setting and you buy a ground rod holder that goes into the chuck.
Temporary fence post I alway just step in the ground with my foot. In a hard spot I might use a 3 lb. hammer.
   / Harbor Freight Tools that don't suck #10,958
Used ours to drive the ground rods at our shop. We had a heck of time trying to get them in (hammer, sledge, etc) so I got the bit and we put the rods in on the hammer setting without another issue in something like 15 minutes. Well worth it!
   / Harbor Freight Tools that don't suck #10,959
Yes for now... trying to all different approaches of manipulation...
I did find a cut away showing the 4 discs... the security rating of this safe isn't very high... but so far it is wining.
The cleanest destructive way is to drill access for a scope to see the discs turning and line them up...
   / Harbor Freight Tools that don't suck #10,960
I'm a big fan of SDS Hammer Drills from my construction time in Austria... EVERY house has a Hammer Drill... masonry and concrete construction is the norm where I was.
1999-2010 Ford Pickup Truck Bed (A55973)
1999-2010 Ford...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
John Deere 5115M (A57148)
John Deere 5115M...
