Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #11,341
I needed a shorter version of the magnetic tool holder so I wanted to remove a couple of the individual magnets prior to cutting the base. I used a heat gun for 20 seconds or so and then was able to pry the magnets away from the base. Some very sticky stuff in there - in addition to magnetism - that was holding them in place.
   / Harbor Freight Tools that don't suck #11,342
Good to know, I have a coworker that took a couple apart... I didn't remember him saying anything about goo...
Speaking about HFT magnets, I have the ITC membership right now and they have a coupon for the 22" rolling magnet bar for picking up stuff for $30, the 22" and 30" specs look similar but there's more info on the 30" but the 22" says it's adjustable height, but doesn't say anything about the strength of the magnets other than it can pick up 9 pounds which is much lower than the 50 pound rating of the 30"... confused... both have quick release handles, adjustable handles, 7" tires, etc...I'm tempted but haven't had time to read too many of the reviews for both to weed out the reasonable information...
After 7 years, one of the tires on my HFT 4x8 trailer has sprung a leak, will get it off here shortly and look into it.
   / Harbor Freight Tools that don't suck #11,343
re a rolling magnet bar, I bought HF's $10 version. 17 In. Mini Magnetic Sweeper. Claimed 4.5 lb pulling force. The magnetism is adequate for washers, nuts, bent framing nails. On a flat floor it doesn't skip over objects that it should lift. Even when running it across a small pile of debris collected by sweeping with a broom. However - I used it on the lawn to find roofing nails dropped by the roofers and the handle-to-bar joint bent immediately. Classic Early-HF, more flimsy than you expected. Way too flimsy for anything but smooth floor, and don't hit a table leg or it will fold up. I reinforced the joint with a right-angle shelf support and hose clamps, now it's sufficient for occasionally finding a lost nut that went under the workbench etc. I recommend get one of the more expensive versions, skip the cheap one.
   / Harbor Freight Tools that don't suck #11,344
If we're talking about the same axe, the website says it has a Lifetime Warranty. :confused:
http://https://www.harborfreight.com/35-lbs-fiberglass-axe-61159.html?_br_psugg_q=axes+26+hatchet
Maybe they mean the lifetime of the axe. :)
Update. I'd actually made this comment in jest, as "lifetime of the [product]" leaves a bit of room for interpretation. Say, the axe eventually wears out after normal use. It's lifetime has arguably ended before the warranty has been exercised. So no free replacement. ;)
Well, I was in HF yesterday and bought that very axe. I commented to the manager that it looked pretty sturdy. He said "Yes, Lifetime Warranty. I tell Harbor Freight if they put lifetime warranty on a product, they should expect me to replace it if there ever is a problem with it!"
I didn't ask if I'll need to keep my receipt. As Woody Allen says, "Eternity is an awful long time, especially toward the end". :laughing:
   / Harbor Freight Tools that don't suck #11,345
That's why I asked, I had one of those flimsy things with 2" wheels and it wasn't sufficient, the axle supports are goofy as well and I think one fell out... Maybe I'll just go to the store and see the difference.
   / Harbor Freight Tools that don't suck #11,346
Any of you, with the HF 20 ton press, might be interested in this air over hydraulic 20 jack, to upgrade your press. I bought mine shortly after getting my press. It's a really nice upgrade.
My only complaint is that the spring, that pulls the jack rod back down, rusted in our high humidity. I plan to remove it, stretch out out, and spray it with some rust reformer, then some black paint.
2 Ton Shop Press - Hydraulic Shop Presses on Sale
   / Harbor Freight Tools that don't suck #11,347
Also highly recommend. I replaced the stock jack on my 20T HF with air over hydraulic and makes the press so much more friendly to use. No more 'jacking' by hand. Just push the lever for air!
   / Harbor Freight Tools that don't suck #11,348
I dont have 1 but I DID watch the vid of the conversion on Utube.. VERY nicely done..
It seems like EVERY HF item has an "improvement" video.. & most are on target..
The sand blaster mods, the parts washer mods & the 20T shop press mods are all hi on my list of fav. videos.
   / Harbor Freight Tools that don't suck #11,349
You always get the HF promo Tool Disposal Notice....is this a tongue in cheek way of saying that you will be throwing it away some time after you buy it? :stirthepot:
   / Harbor Freight Tools that don't suck #11,350
Well sure. The sale ads declare Won't Last Long!!!! :D
40ft High Cube Shipping Container (A57453)
40ft High Cube...
We do NOT accept credit cards as payment. (A57148)
We do NOT accept...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
2005 POLAR TANK (A58214)
2005 POLAR TANK...
ut (A58376)
ut (A58376)
