Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #8,501
I mounted the magnetic strip to the back of my tractor and use it to temporarily store hitch pins, etc when changing or adjusting implements. It sure beats dropping the pins on the ground, setting them on top of a tire, a fender, inside the cup holder, or just generally misplacing them.
   / Harbor Freight Tools that don't suck #8,502
That caught my eye too.
"The Beverly Hills property, with a white-brick Regency mansion, outhouses and manicured gardens offering uninterrupted views of the city". I presume they meant outBUILDINGS.
   / Harbor Freight Tools that don't suck #8,503
THAT is a GREAT IDEA !!!!
   / Harbor Freight Tools that don't suck #8,505
Ditto!!! I need to mount one on my Qhitch!
   / Harbor Freight Tools that don't suck #8,506
I tie the free magnetic tool holders on heavy twine and stick them on the wall around my shops, I've probably one for each shop. Then when I invariably drop a metal part, like a washer, bolt etc. If I can't find it immediately I use the bar to drag and find it. Saves a LOT of bending over.
   / Harbor Freight Tools that don't suck #8,507
YEP!! I have done the same thing. I've been trying to find a broom handle or something similar that I can easily attach one to. Haven't found the right combination yet.
   / Harbor Freight Tools that don't suck #8,508
Going to add that mod to my BX. Good thinking! :thumbsup:
   / Harbor Freight Tools that don't suck #8,509
For finding lost screws I have HF's $10 mini-magnet on wheels. It's flimsy. I had to add an angle bracket between handle and base (using hose clamps) before it was suitable to push blindly under the workbench, or run in the gravel in front of my barn stall/shop.
It's also handy to clean up scraps of mig wire after a welding project.
Also their 'hockey puck on a stick' magnet for when the wheeled one won't fit into a tight space. I bought this one first, don't need it much.
   / Harbor Freight Tools that don't suck #8,510
What a great idea.
Do the larger items, like toplink pins, stay on over rough ground and bouncing around?
PREDATOR 8750 GAS POWERED GENERATOR (A58374)
PREDATOR 8750 GAS...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
John Deer 3 Point Quick Attach (A59076)
John Deer 3 Point...
2005 Isuzu NQR 4 door box truck with folding gate (A56435)
2005 Isuzu NQR 4...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
