Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #9,031
Thanks, Spyderlk. To make a long story short: using a pulley diameter of at least 16 times the wire rope diameter preserves 90% of the cable's strength under load.
So for the 3/8" cable on my logging winch, I should have a 6" pulley. My self-releasing snatch block is a bit smaller than that (I'm guessing 5"?), so I don't quite have 90% strength, but the cable is rated for a whole lot more than my winch can pull, so I'm probably still in good shape.
Im betting your logging winch abuses the cable much worse than a 6" pulley. -- Cable winding upon itself can become disorderly resulting in portions being more sharply flexed or pinched ... sometimes to the point of actually bending or crushing the cable form.
   / Harbor Freight Tools that don't suck #9,032
I've already had that happen so badly that I had to replace the cable. Usually I just get a mild wave in the cable from a poor wind that is put under tension. The secret to avoiding that is to never wind the cable in without tension on the line. If you have to do so, then unwind the cable well past the loose part and rewind it with tension before using it under load. Winding a cable under heavy load on top of loose wraps is a sure recipe for kinks and tangles.
The real damage I did to my cable was when it came off the self-releasing snatch block the wrong way and jammed between the pulley and the back plate. One of my two self-releasing blocks was prone to this - it has since been modified to prevent it from happening again. Normally, I would have just cut out the damaged part and shortened my cable. It's 230 feet long, and I rarely use the whole length. Unfortunately, this one happened almost exactly in the middle of the cable. Since I quite regularly go over 115 feet, I had to replace the cable.
   / Harbor Freight Tools that don't suck #9,033
Good experience and deduction. I have noted some of these in my very limited use of winches.
The quandary I would face is judging when to replace, factoring useload safety factor against damage.​
. . . and CYCLES :eek:
   / Harbor Freight Tools that don't suck #9,034
Good experience and deduction. I have noted some of these in my very limited use of winches. The quandary I would face is judging when to replace, factoring useload safety factor against damage. . . . and CYCLES :eek:
This was so badly kinked it was obvious I had to replace it. It caused problems winding the cable, and would trigger my self-releasing snatch block to release every time the kink passed through the block.
   / Harbor Freight Tools that don't suck #9,035
Bought the 3 point quick hitch. Don稚 know how I lived without it. Over all quality seems good. A couple of complaints.
First the top link pin the send with it is junk. It is already bent after a few hours use. Looks like I値l have to cut it to get it out. Thankfully replacement part only a couple bucks.
Second (and this is not hf fault) I have a new bush hog and tiller. Neither of them will work without modification or the top link adapter. HF does not sell the adapter in store. Thankfully Rural King had one. That makes is a hair less convenient. However since I have to get off the tractor to hook up the pto no big deal.
Finally I added bushings to remove most of the slop.
Overall I am happy. I will frequently need to drop the bush hog so I can drag the arena. Also this will make it easier to grab the tiller when I want to use it as a counter weight in closer quarters than the bush hog will allow.
   / Harbor Freight Tools that don't suck #9,036
Oh man, I use my HF QH all the time. Very thankful I have it. Took a couple small mods but well worth the time and effort.
   / Harbor Freight Tools that don't suck #9,037
Absolutely. I think if I really wanted to shaving the thickness of the top link hook would solve most of my problems. I may end up doing that but honestly the top link adapter is no big deal to me. It pushes the top back several inches. That can be fixed by adjusting the length of the top link.
   / Harbor Freight Tools that don't suck #9,038
I narrowed my hook and used the hidden pins. Someone found an extended hook for like $20, which solves the problem too. The thing makes an implement change take 2 min instead of 20. So many times I wouldn't have bothered changing if I didn't have the QH.
   / Harbor Freight Tools that don't suck #9,039
Yes even with using the adapter the change takes but a minute. My issue is lower back problems. If I am having lower back pain I would not even attempt to change. With this I can do it. PTO hook up will hurt, but is doable. Even when the back is not in spasm, for $100.00 it is a no brain decision.
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Chemical Containers Tank (A57148)
Chemical...
New/Unused CFG Industrial XZ20R Mini Excavator (A57453)
New/Unused CFG...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
