Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #4,931
Apparently this fella found a tool that does not suck. He is selling his used 16 ton pipe bender Search results for: 'pipe bender' for nearly twice the price he paid for it. Hydraulic pipe bender
Yeah. I don't understand that. You see those marked-up items on Amazon, too. I wrote a review saying 'just do a search on [brand name of tool] then go to the nationwide chain where they will sell you the same thing for half the price and including an exchange warranty". I posted a 'review' like this once for a HF pump, another time for a Ryobi jig saw.
Obviously the person who listed the item on Amazon will run down to HF etc and just buy one when some sucker places an order. Caveat Emptor.
   / Harbor Freight Tools that don't suck #4,932
Almost every tool in my shop is for sale at 20% off.........whatcha need?:laughing:
   / Harbor Freight Tools that don't suck #4,934
Sorta off the topic, a bit. I noticed that HF has Cat. 1 top links for $24.95 list... so with your ever-present 20% off coupon, a new top link is only $20! Not a premium product, but serviceable.
   / Harbor Freight Tools that don't suck #4,935
I've thought of looking at there cat 1 quick hitches. Anyone have one?
   / Harbor Freight Tools that don't suck #4,936
I put one on my Yanmar a few years ago. It seems ok. My problem is that my box blade, a no-name cheapie, does not work well with it. I have to move the top hook when I put the box blade on.
I made a couple of bushings because the pins on my mower and box blade are significantly smaller than the hooks on the hitch.
Changing attachments is quicker than before.
   / Harbor Freight Tools that don't suck #4,938
Quick Hitches: highly recommended. Harbor Freight's is cheapest (especially with 20% coupon), and indistinguishable from the one at Tractor Supply. Both are about the same as Deere's more expensive I-Match but I suppose the I-match can be used on greater hp tractors.
1). You can back up to an implement such as a box blade or disc and shove it around until it lines up, contrasted to muscling the implement into alignment with a BF bar - after the implement has been parked a while and started to sink into the ground. For that alone its worthwhile.
2). It's a time - and back - saver every time you mount an implement. Even mounting a trailer ball - just drop the side to side towbar with ball attached, into the hooks, instead of spreading the tractor's arms apart to put pins into sockets.
3). I've used mine as the basic chassis for some welding projects. Here's a mockup starting to build a toolbar to pull a spike harrow. (there will be short chains from this bar back to the harrow). And I built it so that the harrow can now be lifted. The QH serves as the structure for the pinned-on lifting 'winch'.
Total cost $100 for the spike harrow plus scrap on hand.
228185d1315079829-new-toys-spike-harrow-p1650531rtoolbarmockup-jpg
307656d1363028011-harbor-freight-tools-dont-suck-p1710751rspikeharrowlifted-jpg
Rear forks I fabricated.
'Po Boy Ballast Box' assembled in 2 minutes from materials on hand.
390836d1410972768-po-boy-ballast-box-kimg0243rqh-ballast-jpg
Note implements come in all sorts of random widths. There is a 'Standard' for a QH but expect to make minor improvements to your implements to match your QH. Photo - I shimmed the pins on this little disc to match the width of the HF QH.
And finally one of the many QH threads. The last post in that thread has a photo of the upper link adapter ($18) you might need for some implements that are built in a way that obstructs the QH's top hook.
In summary, just do it. You'll wonder how you got by without it.
If you look at that You-tube comparison HF / I-Match, be sure to look at some of the other vids too. That vid favors the Deere version but I think for a lower-hp tractor, the HF one at a third the price is a better buy. Update - I looked at several of those vids, didn't find one that I would recommend. Don't bother.
   / Harbor Freight Tools that don't suck #4,940
Anybody have experience with the little disc/belt combo sander? Worth $60 when similar units at Home Depot, such as Ryobi etc, costs twice that?
I have the smaller version that uses a one inch belt. Works fine after typical post purchase adjustment. Great bang for buck.
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2225EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
