CNC Dan
Cable ties not very good. Made with a brittle plastic. Broke a few with my hands just tightening them.
Were they the black ones, or the off white ones.
I have had good luck so far with the black ones.
Can't remember if I posted this, but the thread is so long, it's getting tedious to read.....lol
The Predator Engines are a deal. I remaned the engine on my little Troy Bilt cultivator tiller, it had a worn, oil burning Tecumseh 3 horse horizontal shaft engine that worked but kept the 'skeeters' away too. A pint of oil to a tank if gas.... It had to go and it did,
Replaced it with a Predator 3 horse horizontal shaft engine for 99 bucks. I didn't expect much for 99 bucks, but it's the 'little engine that can'.... Took about an hour to fit it up and install the guards back on the tiller. Starts typically with 3 pulls and runs like a champ. Don't burn a drop of oil and is miserly on gas too. It's a good buy for 99 bucks, would be good at twice that price IMO.
My little tiller is good for another 20 years.....
Additionally, I bought a HF 2500 PSI gas driven pressure washer (also with a Predator Engine). Comes with a powder coated roll about cart, 4 different spray nozzles and a 25 foot (too short) hose. Been going strong for 2 years now washing tractors, cars, campers, houses, decks and driveways and shows no sign of quitting.
I bought a spare pump from Northern for it just in case, but I change the engine oil and pump oil at the same time (twice yearly) and I stays in a heated shop in the winter. I think the biggest failure in pressure washers is people letting the water freeze in the pump. Not an issue here.
The only downside is the hose that comes with the unit is wimpy and too short. You have to be careful not to kink it, if you do, it's shot.
Was 299 bucks another great buy IMO.
Neither suck at all.
H.F is ok but to buy something for lifting overhead even jack stands I would have to re weld it before I used it for peace of mind.Other things like sockets are ok to buy.
I have a set of HF jackstands and a set of jackstands from Autozone and both sets (except the paint color) are identical right down to the casting number on the adjustable cast steel foot. Big difference was price. The HF set was 25 bucks less that the 'Zone set.
I put my one ton Ford Pickup up on those 4 stands all the time.... No issues.
