Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #5,261
Yes the battery connection is all important a poor connection can give a misleading or weak reading. The Cen Tech has that impedance measurement feature.
I tried out the one I have on 4 different batteries...one was an unknown age (but at least a 2 year old minimum) Walmart purchased motorcycle battery that will start and run the bike but wont hold the charge after a day or two, another Walmart battery bought and I put in new in 2014 for my JD diesel tractor. the third battery was for my 8 cyl Durango. A battery I just had installed by a local garage back in June after the old one just completely failed and left me stranded out front of local lumber yard, and the 4th is a brand new lawn tractor battery I also purchased in the spring of 2015 from local auto parts store.
Both the JD battery and the lawn tractor battery showed readings better than the listed CA/CCA, the motorcycle battery gave a reading of less than half the assumed CA/CCA (it wasn't marked but it took a ejumacated guess from several similar ones found online). But the kicker was the "new" SUV battery it was showing readings about 10% lower than the listed rating. :eek: I'm trusting the garage didn't screw me on the battery and its all with the terminal connections in the reading. I haven't had any problems but I'm watching it and tomorrow will be a good test because its going down 14 degrees with a wind chill of -5 I seem to have constant terminal corrosion buildup problems with vehicle even using sprays it always comes back even with new battery.
I have made a habit now of marking the purchase date right on the battery with a paint pen too!.
Kent Bergsma has a decent series testing a battery's performance and also using these and other different types of testers
   / Harbor Freight Tools that don't suck #5,263
Yesterday I picked up their little 1x30" belt sander for knife sharpening duty. It's awful hard to complain about a $50 tool. (so far so good) Waiting for some proper (knife) belts from amazon to give it a real try.
Their red roll around tool cart, like 5 drawers? is built sturdy and the drawers work well but the locking mech that is supposed to release the drawers when you open the lid does not work on it's own. I've tryed to lube them but they do need to be pulled up manually. I'm still "moving in" to it trying to decide what tools I want mobile.
   / Harbor Freight Tools that don't suck #5,264
   / Harbor Freight Tools that don't suck #5,265
I have that sander. Works fine after readjusting a bit. It is often on sale for ? less than $30. Well worth it for light duty work.
   / Harbor Freight Tools that don't suck #5,267
Generaly everything go's on sale just after I buy!:eek:
You can take a better price and your receipt back, for refund of the difference, up to 30 days after your purchase.
Sent from my iPad using TractorByNet
   / Harbor Freight Tools that don't suck #5,268
5/16 grade 70 chain now on sale.
Bruce
   / Harbor Freight Tools that don't suck #5,269
And so is the 1.5 ton aluminum floor Jack for $59.99. I got mine a couple of years ago on a $49.99 super coupon.
I have a 3 ton for bigger lifts but, use this one most of the time.
   / Harbor Freight Tools that don't suck #5,270
Great deal
2007 Toyota Camry (A56859)
2007 Toyota Camry...
SKID STEER ATTACHMENT BRUSH WITH BOX (A58214)
SKID STEER...
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
MONTANA MOUNTAINEER 5TH WHEEL CAMPER (A52708)
MONTANA...
Willmar Wrangler 4500 (A56435)
Willmar Wrangler...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
