Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #6,601
Has anyone used this Harbor Freight Belt/Disc sander? At $70, the price is right, especially if I order while the 25% off coupon is still good. This is for my wife, who does some woodworking, but is not good at "tweaking" or dialing in tools to get them to perform at their best. From reading some of the reviews, I'm concerned that this tool is probably not the one for her, but I thought I'd check here to see what your experiences have been.
   / Harbor Freight Tools that don't suck #6,602
I haven't used that one but do own the 1" belt sander sibling tool. It works fine after some rejiggering of rollers and belt to get things lined up properly. Not a high quality tool but certainly good bang for the buck.
   / Harbor Freight Tools that don't suck #6,603
Isn't that the one where the shield around the disc sticks out farther than the sandpaper, preventing sanding wood longer than the disc diameter?
Bruce
   / Harbor Freight Tools that don't suck #6,604
This is the wide 50 Cal box. Real metal and real rubber seal. I about cleaned them out:
   / Harbor Freight Tools that don't suck #6,605
I have had one for years and although it is not a high end tool it works very well. Ive sanded wood and metal with good results. It's just a sander, it is a good value especially with the 25% discount. GO FOR IT.
   / Harbor Freight Tools that don't suck #6,606
I've never had much luck with any of their electric tools. They must use the worlds softest brushes cause that's what seems to go first. In most cases they even supply a second set so they know.
   / Harbor Freight Tools that don't suck #6,607
I'm the one who posted a review a few pages back in this thread describing that problem. Yes the manufacture was so cheap and sloppy that it couldn't be assembled to become a real sander. Also while the website and the carton declared 41 lbs, there was a shipping label pasted on the box declaring shipping weight of 23 lbs as I recall. It certainly felt light and flimsy.
After a couple hours trying to re-engineer it to assemble into something useful I took it back and bought a Ryobi that did weigh 40+ lbs and ran flawless right out of the box.
Some of the reviews of the HF sander said so weak he had to push the belt to get it started.
Some reviews here indicated the tool sold in the past under that description worked ok. I think HF changed suppliers without changing the model #.
In summary not many of HF's products are 'pretend' tools but this one is. Don't bother. Buy the Ryobi if you need what this one should be capable of.
   / Harbor Freight Tools that don't suck #6,608
I have that one. Had it for 5 yrs or so. I mainly use it for sharpening/shaping HHS bits for my lathe.
   / Harbor Freight Tools that don't suck #6,609
I've had one of those belt/disc sanders for about two years. Not a woodworker, but find it handy quite often. It is a little weak on the power, and it did need some minor tinkering, but it is well worth the $54 I paid.
If money is not a factor, or you plan to use it often, I would recommend an upgrade.
   / Harbor Freight Tools that don't suck #6,610
I looked at the belt / disc sander several years ago and ended up buying the 12" disc sander instead. It's an excellent tool. The direct drive 12" disc is heavy so, has lots of inertia once it's up to speed. I use it primarily for wood working but, it can be used for metal work as well.
12" Benchtop Disc Sander
This was about the time Ridgid introduced their oscillating belt / spindle sander. Caught one on a super sale at Home Depot for $99.
Oscillating Edge Belt / Spindle Sander | RIDGID Professional Tools
This is one of my most used tools in my woodworking shop.
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A58018)
2014 PETERBILT 384...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
