Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #13,661
Mossy, don't forget to put some air tool oil in the air inlet....
There are some out there that are oil less. I don't know what happens if you oil them, I assume damage to gaskets?
   / Harbor Freight Tools that don't suck #13,662
I also bought one of their palm nailers.
Compact Palm Air Nailer
It was about $26 after coupons. Wow, it actually works very nicely for putting in truss nails in the brackets in tight spaces. Dirt cheap and works. That's just crazy talk.
Yep, great tool for truss hangers, don't know what I'd do without it now.
   / Harbor Freight Tools that don't suck #13,663
I like mine, too.
   / Harbor Freight Tools that don't suck #13,665
If I had a hammer.
I'd hammer in the morning
I'd hammer in the evening
All over this place
I'd hammer on a rafter hanger.
I'd hammer on a truss plate
I'd hammer out a hurricane tie.
   / Harbor Freight Tools that don't suck #13,666
Over the years, I've used a sparkplug, and clamp to make several spark checkers. It's been difficult to clamp them in a position so I could see the spark on all of them. The other day I tried this one In-Line Spark Checker
In the two times I've used it, it was easy to hook up and the light was easy to see. I like it.
   / Harbor Freight Tools that don't suck #13,667
Late 1990’s I had a John Deere 21SP (I think) self propelled walk behind mower with Kawasaki engine. Keeping the self propelled drive operational was the death of that mower. Loved the Kawasaki engine but for one quirk: it would quit running with a 3 year old spark plug. Remove plug and plenty of spark. After much head scratching installed a new NGK plug anyway and it ran another 3 years and did it again. And again 3 years later.
Old plug sparked fine out, but not in. The electrodes looked great after 3 years.
Am guessing the spark was weak. Later heard of others with same issue.
If only the self propelled drive didn’t eat exotic John Deere proprietary belts and high wear on plastic gears and steel shaft in wheels and $25 tires (in 1999!) I’d still be using this mower.
Currently mow with 56V EGo 21” self propelled. Not as powerful as any gas mower I have used but gets the job done.
   / Harbor Freight Tools that don't suck #13,668
I think it was a youtube mechanic who said a sparkplug that would fire outside of the engine wouldn't always fire in it and recommended using something similar to the spark checker to test with the plug installed.
   / Harbor Freight Tools that don't suck #13,669
I bought the jiggler syphon from hf yesterday. I was going to buy the standard syphon tube with the ball in the middle that you squeeze. I never heard of a jiggler syphon so for $7, what the heck.
It痴 a good idea with poor execution, imho. You see a lot of that, good ideas are like opinions. Great execution is.....hard to find!
Problem was the packaging. The 5 ft tube was not only too short, my fault, but it was also mashed into an almost flat oval. That痴 because when they roll it up they attach it to the cardboard with zip ties and its 100 degrees out.
I let it sit in the Carolina sun yesterday trying to un mash it but, no way.
Of course the oval shape won稚 carry the volume a circle will. I won a bet on that once.
The metal gadget on the end that makes it work is probably worth the $7 dollars and since the tube was was too short anyway, no harm done.
So.............
I went to Lowe痴 last nite, 8:30 pm, Friday nite, always raining. That痴 the only time to go, imho.
They had a 20 ft roll of clear plastic tubing, perfect. $24. I don稚 blame them but, Nope.
I致e learned. I used to think, make a quality product and sell it as cheap as you can and Own the market. Nope.
The truth is, in general, make an product that people will swallow and sell it for as much as you possibly can!
The syphon sort of worked and I think if I find a decent tube, it will work fine. Kinda neat idea!
But to spend $7 for the gadget and $25 more, just to make it work? Nope
But you know that when you go to harbor freight.
   / Harbor Freight Tools that don't suck #13,670
I bought a set of 1" ratchet straps at HF. They were much better than the ones at Lowes & HD. Much better mechanisms, and had heavy plastic coverings around the metal mechanism where you touch them to cinch and release. I threw the Lowe's POS in the trash.
Moxy MT30S Haul Truck (A55272)
Moxy MT30S Haul...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2002 Ford F150 (A56858)
2002 Ford F150...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
PALLET OF FLUORESCENT LIGHT BULBS (A58374)
PALLET OF...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
