Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #13,881
Along those lines, I wonder if HF delivers the Icon tool boxes to your home / shop. They ain't a cheap date. Actually, I prefer the Menards big boxes myself.
   / Harbor Freight Tools that don't suck #13,882
Has anyone actually bought a tool box from HF that didn't have a dent somewhere on it? Both of mine did. I straightened them myself but it seams like a common theme.
Sounds more like Tractor Supply where everything is either scratched, dented or broken.
   / Harbor Freight Tools that don't suck #13,883
When I bought my 44 boxes several years ago, I fully expected dents when I got them home based on everything I had seen online. Happy to say, both were dent free.
   / Harbor Freight Tools that don't suck #13,885
1 in. Sliding Compound Miter Saw
I searched this thread and didn't find much about this sliding mitre saw.
Anyone own one and is it ok for basic homeowner use?
thanks Drew
Drew, I have owned one of those for about 10 years, worked it harder than just 'average' home owner use. Cut a lot of pressure treated and regular lumber, plus a bunch of laminate floors. It finally started acting up, the slide getting tight, and turning the base got harder. I still have it, but only use it for those 'not too precise' type projects.
I think it would suffice nicely for your projects.
   / Harbor Freight Tools that don't suck #13,886
Ted, thanks. Mostly going to be used for cutting 8 inch cedar boards for bird feeders and bird houses.
Next price point up is about 80 bucks more, I want the "sliding" version so I can cut a wider board if need be.
90 day warranty is dubious, everyone else is 1-2 years.
   / Harbor Freight Tools that don't suck #13,887
   / Harbor Freight Tools that don't suck #13,888
Yeah, that up grade is well worth the difference....
Drew, you can always get the extended warranty program.... it truly is a "full replacement warranty". I have burned out (let the smoke escape) from a few HF tools.... they replaced them no questions asked. It's based upon price, but for the money, can't be beat. I usually get it on anything over $50....
   / Harbor Freight Tools that don't suck #13,889
I have a version of that, my HF spreadsheet indicates that I got it just over 20 years ago. Don't use it very often, but it does what I need. I figured at the time for $100 it was worth having rather than trying to cobble up something hazardous if I ever needed a compound miter cut down the line.
Repeatable angle cuts and being able to set a stop for consistent length alone is well worth it, plus being able to cut wider stuff.
   / Harbor Freight Tools that don't suck #13,890
I bought the 12" about 2004 to do a laminate floor in the den with a lot of weird angles. The first thing I did was get a fine tooth Diablo Blade, I think 80 tooth but don't remember for sure. Back then it was around $20. After the den I built a 16' x 24' deck with p.t. 2x6,4x6, and 4x4's and laminate sub structure & Trex decking. Several other projects then gave it to a young Navy friend who was doing a remodel and it is still running strong. The only problem I ever had was the laser light went out but I got along fine without it. My buddy replaced it with something from Amazon and it works fine.
I don't know about the new ones but that old one was a definite yes buy it.
2016 Ford Explorer (A56859)
2016 Ford Explorer...
Cushman Electric Cart (A55853)
Cushman Electric...
1620 (A58375)
1620 (A58375)
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
