Bedlam
Veteran Member
- Joined
- Feb 28, 2005
- Messages
- 1,878
well said Lostcause..
I read your post a couple more times.... I get what you're trying to say. But its a little much to expect that the low end Hobart/Miller/Lincoln welder will be 10 times the welder of the CE90. Being twice the welder specs-wise, and ten times the welder quality/longevity wise, is a fair competition to me.the problem is that you can't compare them because the big name manufacturers don't make units like this, and even what they do make is not at the total opposite end of the spectrum. 10%, 20%... sure, it's a two fold difference, but it's nowhere near the 60% that you approach with most anything well built and using a 240v plug.
You had one fall apart and two not... But either way.... there is only one kind of wire for this thing. The guy talking about the 6013 rod was using a stick welder not a flux core.It isn't going to fall apart, it will work on jobs of appropriate for the size of the welder and using better quality wire will produce grindable welds.
