RPW clearly I bought off of price point but I did "confirm" from posts on welding forums that the HF 90 flux core wire welder does work.
The post that lead me to buy was from a stick welding guy who bought this 90 amp HF welder a few years before he posted. He tried it without success and put it on a shelf shortly after he bought it.
He decided to take a wire welding class and dug out the HF after it setting for years. He said now with a better understand of wire welders and how to set them up he gave the HF wire welder another shot. He addressed the feed issue by moving to a .035 tip vs the .030 and the quality issue by moving to Lincoln wire. He found the Lincoln stuff at Lowes. On the way home I picked up the Lincoln wire and tips that I am going to start with.
He reported after he understood the "wire welding" differences and set up he was able to weld with the HF just fine up to its thickness limits.
Some reported they liked the Hobart wire better than Lincoln but one did state after some weld testing he when back to the Lincoln wire because of the test results. Some report the HF wire to be just fine.
Because all the input is so subjective I am going to wait until I try it before I decide.
We had storms all weekend and with Scouts and Dance the kids are tied up today until 8/9 PM. I want to try it now but it will be better if they get it out of the box and we set it up together. The on-line manual is in the link in the opening post of this thread and I have read it several times. The kids have to read the manual before I will let them get it out of the box.
If I had a "real" shop set up at this time I think I would have just paid 3x more for a name brand box but the duty cycles seem to be about the same for all welders in the same class. Some think they are all build off the same set of technical plans but with different quality of parts and labor. Removing the cases and setting a good fan blowing through the welders seems to boost the duty cycles. The HF per the print in the manual does have some type of internal fan.
Harbor Freight is not for everyone. Paying 300-500% more for Snap-On, etc is not for everyone.
If our welder works at 40 pounds I can carry it anywhere and if in the MH I can use it anywhere. If the 50' 12 gauge extension cord does not cut it we will get a 10 gauge. We have 30 amps in the garage where we plan to use it by tapping into the 30 amp RV outlet. It is recommended to have these 115 volt welders on a 20 vs. 15 amp service with slow blow/trip protection because they can pull 24 amps initally.
When we get it set up I will spell out the results. I may even test the builting in termal breaker if I can keep a bead running for that long.
