Hard water deposits slowing flow.
   / Hard water deposits slowing flow.
Also try taking the screen flow restrictor off the end of the fixture ( where the water comes out).. They usually stop up & cause flow problems
I replaced the faucet
   / Hard water deposits slowing flow. #12
If you have junk in the lines.. You could still stop up the small screen & flow restrictor where the water comes out..Even in the new fixture. Wouldn't hure to check it.. It should just screw off (hand tight)
Hot water flows fine, just having problems with the cold. thanks
   / Hard water deposits slowing flow. #14
You have a clog somewhere in the system if only the sink is a problem. Start at screen on faucet and then go towards main line until you have good pressure. Once i had large piece of iron in valve in a house with all copper pipe
   / Hard water deposits slowing flow. #15
Did you flush the lines when you had the faucet off? I had my hot line reduced to a trickle by a particle the size of a large grain of sand. I also discovered that the telescoping head was fouling everything because there is an exposed spring in the hose that was rusting and shedding rust particles.
   / Hard water deposits slowing flow. #16
It doesn't have much to do with getting flow back to your faucet, but curious if you've drained the hot water heater to get any sediment out? I've got fairly hard water and had some pretty sizable bits come out into a bucket.
Good thought, I need to do that, just have not gotten to it. Thanks Ed
1270 (A50490)
1270 (A50490)
Bell B30E (A50123)
Bell B30E (A50123)
Pair of New 700/40-225 Alliance Tires with Rims (A55301)
Pair of New...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
