Harrow operating question
/ Harrow operating question #1
mikeg135
Just picked up a used 6 ft 20 disc 18" leinbach harrow for $200. The disc currently spin freely to one another. Are they suppose to spin together?
/ Harrow operating question #2
they all spin independently of each other.
/ Harrow operating question #3
I have never seen a disc harrow designed for each disc to spin independly. I'm not saying it is not possible, I just haven't seen one.
/ Harrow operating question #4
Hmm...my 3PH tandem disc has four gangs. Each gang has a square axle and the disc blades all have square holes. The entire gang turns together.
However, I had an old offset disc whose blades turned independently of each other. When it was taken apart to replace the blades it was discovered that the square axles had round grooves worn in them that allowed the square holes in the blade to just spin on the axle.
With the price of the disc (not knowing the age) you might expect it is well-worn. You might want to pop off the end nut and see if it has a square axle. It may be worn like my offset disc was.
The solution was to weld up the grooves and grind them back to square. Real weldors will cringe at this since the axles were likely hardened steel. But on the farm you sometimes just have to do what works.
After a bit more research looks like the previous owner replaced the axles with a solid round bar. Looks like I will be needing to replace them with some square axles and probably new square bearings. The bearings have a round hole not square hole.
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
x (A68191)
x (A68191)
1819 (A64557)
1819 (A64557)
2012 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2012 CHEVROLET...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
