Has anyone tried putting an electric fuel pump on a Jinma 454?
   / Has anyone tried putting an electric fuel pump on a Jinma 454? #11
Yep, I'm just learning 'bout electric diesel injection.
What I do know is they're opened by solenoid (and there by timed electrically) and not by pressure.
What kind of pressures do they run in the common rail system?
To my knowledge Cummins was the only engine manufacturer to use a Pressure Timed (PT) fuel system. All the rest are common rail, unit injector, or pump/line/injector (PLI). All the Chinese tractors are pump/line/injector. The barrels and plungers in the injection pump are operated and timed by a camshaft, the amount of fuel delivered to the injector is governed by the rack position against the plungers/helix/scrolls. These stock systems operate in the 2,100 to 3,200 psig range.
   / Has anyone tried putting an electric fuel pump on a Jinma 454? #12
I have changed the fuel filter, changed the oil in the pump, checked all the line to make sure nothing is blocked, used the hand pump to prime it, but nothing comes out at the engine, So I am at a loss. Do you have any ideas of things to try?
It sounds like you have a plugged tank suction screen and/or a plugged sediment bowl screen and/or a plugged banjo fitting screen at the lift pump suction.
I cleaned the sediment bowl and fuel comes out of the hose at the top of the fuel filter if I disconnect it. I am not sure what the banjo fitting screen is or the tank suction screen.
   / Has anyone tried putting an electric fuel pump on a Jinma 454? #14
Cummins common rails of the vintage i have -2003 can reach 20,000#s + newer systems can go higher my old Rhino tractor injects at a (low) 2500psi Mechanical injection (in-line pump)
   / Has anyone tried putting an electric fuel pump on a Jinma 454? #15
Dan,
These Chinese tractors are notorious for having a handful of hidden filter screens throughout the fuel delivery system.. the first is in the fuel tank, part of the outlet from the fuel tank. You need to drain the tank and then remove the output plumbing to get to it. Of course, clean the tank while you're at it.
The next one is at the inlet of the sediment bowl, as I recall. It is inside the fitting where the line from the tank attaches to the sediment bowl. There may, on some tractors, be another one at the outlet of the sediment bowl, again, inside the fitting.
Some tractors have a spin-on canister filter after the sediment bowl, and there is often one incorporated into that assembly somewhere, though not always.
Next, there is usually one at the banjo fitting where the fuel line enters the lift pump portion of the injector pump assembly. The banjo fitting is at the point where the fuel line connects to the lift pump - it is shaped like a banjo, thus the name. You pull the bolt that goes through it and you should see the screen under the banjo fitting.
Chinese tractors are also notorious for having rubber that deteriorates quickly in the presence of ozone, ultraviolet light and maybe even bad karma. Anyway, the inside of the rubber fuel lines can become weakened and/or deteriorated to the point where the line collapses internally under suction and shuts off fuel flow, (like sucking on a soggy paper straw) or bits of the lining clog up one or more of those pesky aforementioned screens.
Have you opened the injector lines at the top of the injector pump to see if there is fuel there? Did you open one of those lines when you were trying the priming pump? Did the priming pump develop resistance to being pumped, indicating that it had filled the lift pump to capacity?
As I've already said, these injector pumps are really fairly robust and rarely die. Far more often the problem lies in fuel delivery to the high pressure side of the injector pump assembly, caused by dirty fuel or lines, clogged screens, collapsing rubber lines or diesel bugs clogging everything up. If you have ever had any brown or black sludge in the bottom of your fuel tank, suspect diesel bugs and take all the drastic measures necessary to deal with them. Those little suckers will not only plug things up, they will actually corrode the metal parts of the system, necessitating replacement of more expensive parts.
Well, there's a run-down on what is involved int he fuel delivery system and the sequence to use in checking it all out. Be sue you've ruled out all the simple possibilities before ordering a new injector pump, unless you just have money to burn.
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
Life proof SPC Luxury (A53117)
Life proof SPC...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
