Hauling tractor with a car trailer?
   / Hauling tractor with a car trailer? #71
My ramps are the same.
I would block it up. There have been a few guys get killed or seriously injured doing what you do. The rear tires come up and now PARK and the parking brake are worthless. One guy on this site banged up his tractor, trailer, and F250 doing just this. He ended up with only a broken arm.
Be careful.
Chris
May be a bit dangerous but only if on a incline, otherwise it just kicks up a bit and then once the front wheels hit the trailer a bit, it settles back down. How in heck would loading a trailer cause the truck to just sideways 2 feet unless you had the wheels turned or your trailer jackknifed which is a big NO NO in all cases. I park mine straight in line with the trailer and front tires straight. I have a raised road bed out to my shop that I like to park the rear of the trailer up against it. It allows for less angle on the ramps and the frame of the trailer is only a few inches off the ground so it doesnt lift the truck wheels up off the ground before the tractor gets on the trailer. On flat ground the truck will skid forward a bit if someone isnt holding the brake pedal but nothing dangerous to do in my mind at least. I always use 4 wd on the tractor so it climbs up the ramps on its own.
Chocking the front would be good, but if I am going to carry around a bunch of loose material, I will just carry some jack stands to put under the trailer frame. I have been thinking that maybe I can design some support stand that will fold under the trailer and pin up after loading. That would avoid piling in a bunch of loose stuff in the truck. I think that would be pretty easy to build and install on the trailer.
   / Hauling tractor with a car trailer? #72
Be careful.
Chris
You could also put the truck in 4wd to have "park" apply to the front wheels as well
   / Hauling tractor with a car trailer? #73
Not sure that works with electronic 4wd, never tried it but I do know there is a 2 second delay before mine kicks into 4x4 after the motor is started...Maybe if the tow vehicle is left running while loading?...Who knows. I'm not trying that.
   / Hauling tractor with a car trailer? #74
Sounds like we better all be using our seat belts., at the very least.
rimshot
   / Hauling tractor with a car trailer? #75
It may not work with that, my trailer ramps have stands so I don't have to worry about it
   / Hauling tractor with a car trailer? #76
It works on my Fords and Nissan. There would be no way to load and unload the boats I do without it. Not sure about other brands.
Chris
   / Hauling tractor with a car trailer? #77
Chris
Are they running or shut off..That's the question.
   / Hauling tractor with a car trailer? #78
I never shut off on the ramp but my guess is they would since vacuum holds the hubs. So no running, no vacuum.
Chris
   / Hauling tractor with a car trailer? #79
Chris
I've never had mine slide on in the snow when parked on a slope running and in 4x4...So I assume that it's also loked in. My curiosity was whther the gears stay locked with the power off...I'll have to test that once..True no motor, no vacuum...But I still wonder if the gears remain engaged if the 4x4 was in when shut off.
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
Toro Sand Pro (A56859)
