Having to jump-start my D110
   / Having to jump-start my D110 #11
A person that owns a battery should have a charger. Many of the new fangled chargers won't work at all if the voltage is below 2 VDC or so. They just call it DOA. The Battery Tender Juniors are a neat little maintainer that will bring a battery to full charge and hold it there. Nothing will replace a load test or plate inductance test to determine battery health though. Set up a draw test , then remove the red wire that feeds the voltage regulator. There's your draw.
A terminology correction on my behalf. What I have been charging the battery with is an actual 6V/12V charger, not a 'trickle' charger.
I think that I got it in my head due to the literature/manual that said that "once the battery is charged it will switch to 'maintenance' and supply a trickle..." I do know that it won't save a battery if it's too far gone, though. Mind you, it only has three coloured LEDs on it; red - power on, amber - charging, and green - charged.
What I've discovered now is that "charged" is voltage only... amps takes a wee bit longer.
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2012 International Prostar (A56438)
2012 International...
Pair of 2001XA800Z Yamaha Jet Skis (A57453)
Pair of 2001XA800Z...
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
Takeuchi TB016 (A53317)
Takeuchi TB016...
2017 Jeep Wrangler Unlimited Sport (MPV), VIN # 1C4BJWDG5HL577343 (A57453)
2017 Jeep Wrangler...
