Hay Moisture Tester - Recommendation?
   / Hay Moisture Tester - Recommendation?
I see, where is the sensor mounted on the baler?
In the bale chamber. Right, rear side just below the rail you see on the outside. It starts getting a reading when the bale gets to around 22" if I remember correctly.
I can take some pics the next time I bale if you would like to see it.
The baler mounted unit is way slick. I have a monitor in the cab that I keep an eye onthe mositure and stop baling when I see the moisture picking up in the evenings.
D.
   / Hay Moisture Tester - Recommendation? #22
Yes, a picture would be appreciated. Thanx
   / Hay Moisture Tester - Recommendation? #23
Hello everyone,
I just purchased a DELMHORST F-4 Hay moisture tester kit on ebay.
From what I have been able to find out, this model was made in the early 80's. I called the company and they still provide service on this model.
If it works, I think I got a good deal. If not, maybe I can sell it as a collectors item.
Does anybody still use this model? If so, does it work well.
Thanks,
Steve
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
Case 1840 Skidsteer (A59814)
Case 1840...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
