Hay Moisture Tester - Recommendation?
   / Hay Moisture Tester - Recommendation?
I see, where is the sensor mounted on the baler?
In the bale chamber. Right, rear side just below the rail you see on the outside. It starts getting a reading when the bale gets to around 22" if I remember correctly.
I can take some pics the next time I bale if you would like to see it.
The baler mounted unit is way slick. I have a monitor in the cab that I keep an eye onthe mositure and stop baling when I see the moisture picking up in the evenings.
D.
   / Hay Moisture Tester - Recommendation? #22
Yes, a picture would be appreciated. Thanx
   / Hay Moisture Tester - Recommendation? #23
Hello everyone,
I just purchased a DELMHORST F-4 Hay moisture tester kit on ebay.
From what I have been able to find out, this model was made in the early 80's. I called the company and they still provide service on this model.
If it works, I think I got a good deal. If not, maybe I can sell it as a collectors item.
Does anybody still use this model? If so, does it work well.
Thanks,
Steve
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
