Hay Moisture Tester - Recommendation?
   / Hay Moisture Tester - Recommendation? #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
What are people using for moisture testers?
My dealer says they are a waste of money.
They seem pretty cheap and people say it is good to know the moisture level.
Any advice?
Thanks,D
   / Hay Moisture Tester - Recommendation? #2
I use a Delhorst? Digital Moisture Tester, its an older hand held model with a 10" probe, its great for piece of mind and knowning (as a beginner) what the moisture is and when it starts sweating to be aware of unsafe moistures.
Also had one on the baler/tractor, it was cool to what the bales as they were being processed (baled) what the moisture was, unfortunately it hasn't worked in 2 seasons and it needs to be looked into.
In my opinion- its good to have and your dealer must not be into haying or doesn't carry moisture testers. A quick Google search will find many models available.
   / Hay Moisture Tester - Recommendation? #3
I grab a fistful of hay and starting with my hands about 6 inches apart, I rotate my hands in a bicycle motion and if the hay breaks apart, it is ready to bale.
Cool deal - I talked to the parts guy and he will have me one in the morning. I think a lot of these older guys have been doing this stuff for so long they forget about us new guys now knowing anything about anything.
I am getting a probe model. A baler mounted one might be cool, but I have enough stuff hung in there already it seems.
Thanks,
D.
   / Hay Moisture Tester - Recommendation? #5
I have a Farmex hand held prope and a Farmex baler mounted moisture testers. The hand held comes in handy for checking the pile after the hay is put up. It has a temp feature so I can check both moisture and temp to make sure there are no spikes anywhere.
The baler mounted unit is nice for my area as you can watch as the dew sets. By the time the tires start picking up a little moisture you can see the monitor start reading higher. Since I don't have dry nights to bale this lets me know when it is time to stop in the evening with out having to check the windrow constantly.
But I still check the hay by hand first, then verify with the prope before I bring the baler to the field.
   / Hay Moisture Tester - Recommendation? #6
I also have the Delmhorst with the 10" probe (10+ years old and still works). Its true that once you get some readings from a tester, you will learn what the levels are by feel and sound of hay going into the baler. But you need some values to calibrate your senses.
   / Hay Moisture Tester - Recommendation? #7
this will be my 2nd year baling for myself.
I have done a lot, maybe too much reading, to make this an easy job. As I posted elsewhere here, I think there are 2 levels to getting hay.
1) get it when its dry enough to go into the barn without cooking, going moldy and maybe burning
2) getting in wet enough to keep the leaves on the stems. The leaves, especially alfalfa, conatain 80% of the nutrition. So if you double the number of leaves you can keep on ......
The cloud of dust behind the baler is largely shattered leaves. Lost nutrition.
In arid areas where there is little or now dew, some farmers actually spend big bucks, like $ 25,000 for "dew similators" that are spray systems the spray water onto, and what makes them expensive, into the windrow, to just slightly soften the leaves, so you can keep them on the stems. The baler follows the dew simulator around the field about an hour later when conditions are just right. In big spreads, this means one tractor for the dew machine and one for the baler.
You've really got to hit the numbers right to do this and a properly used meter is a big big help, especially if you don't have 15 years under your belt.
I got a Deere. They all look pretty much the same to me. Do not get one that does not sense temperature. You want to be able to probe the middle of some bales, especially from the lower, wetter parts of your field, to make sure they are not cooking in the barn.
Just called to confirm which one they ordered for me.
John Deere SW16136 does both moisture and temp.
Thanks for the tip,
D.
   / Hay Moisture Tester - Recommendation? #9
Just as a point of reference, the JD models are built by Farmex w/ a 2yr warranty from Farmex. The mdls are:
SW07350 baler mounted w/ a range of 8-44%.
SW07320 hand held moisture/temp meter w/ a range of 8-44% and 32-255F
SW07370 hand held moisture meter w/ a range of 35-75%
SW16136/SW16326 hand held moisture/temp meter w/ a range of 14-44% and 33-250F (the diff between these mdls is the probe length)
The probe on the last 3 above is a pistol grip sort of affair attacked to the meter itself via a cable. The 7320 mdl has the probe built in to the meter.
That is good info. I think I paid right at the same price I found the Farmex. I don't mind giving JD some money - they do a good job of supporting me after the sale.
The baler mounted one is really slick. I can post pics of the install if anybody cares.
D.
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
1998 MACK DUMP TRUCK (A60430)
1998 MACK DUMP...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
UNUSED FUTURE 32"...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
