Hay trailer builds 2 ...
   / Hay trailer builds 2 ... #11
That's a nice trailer base... I read the comments... Have you noticed any problems with the frame bending or tweaking ?? Some folks say it's very light weight and has some problems.... Maybe, they overload it....
I bought mine over ten years ago and from Harbor Freight so it may not be the same. It was not expensive when I bought it -- less than $200 if I recall correctly -- and I figured I would use it hard and see how it lasts. I routinely load it with much more than its rated capacity. The frame flexes a lot, which I think is by design to manage stress. I have worn out three of the four tires and replaced them. But the frame hasn't broken. Similarly, I built a simple wooden box for the bed, and it has held up for over a decade. I did manage to bend the tongue, and it eventually snapped where it was bent, but I was able to bolt it back together.
It does what it does well.
Thank you for the good information... Dave
   / Hay trailer builds 2 ... #13
Copied and moved from "Build it yourself"...
I'm looking for ideas to build a hay trailer to pull behind my 14T and Jubilee tractor...
I'm thinking I want a small trailer for 20 or so bales then drive off of the field and reload on my big trailer for later transport...
I don't want to overwork my Jubilee... pulling the 14T and the hay wagon, might be too much for it.. I can't afford to have it broke down... Sooooo, using a small trailer as a shuttle seems like a good choice....
Any ideas would surely help me decide on a design....
We needed inexpensive multi purpose trailer and had a boat/ trailer combo given to us.
the boats stern drive was to far gone so junked the boat .
Took the trailer and built some brackets and supports added 2 x 6's for the floor. It works well for about 25 small bales and many other uses.
I did have to remake some steel mounts for the slipper springs recently- front perch the Aluminum had stress cracked. Other than that it has been a good trailer
That made a nice trailer.... Good idea.....
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2016 FORD TRANSIT 350 CARGO (A59575)
2016 FORD TRANSIT...
