HD F-150 or 3/4 ton truck?
   / HD F-150 or 3/4 ton truck? #121
Big difference in the mountains of WV and IN. :)
We have 7 miles of a 7% grade going tp our lake on 101 just outside of Brookville. Its as tough as I have driven.
PS, I have driven every state but Idaho, Hawaii, and Alaska. But what do I know...
This is exactly why I traded my F150 EB on a GMC 2500 6.0. Couldn't be happier.
By "this" do you mean component size? because that seems to be the only advantage mentioned over an F150HD. Which would beg the question... has anyone who tows a lot with an F-150 burned out rear hubs, differentials, transmissions, transfer case? and if so, what were the circumstances?
   / HD F-150 or 3/4 ton truck? #123
YEP! Lost the rear end gears(3.73) on my 2006 F150 at 120,000 miles cost to replace $1,900 bucks.My truck has always been well maintained to boot.Maybe I just got a bad one? No sense trying to over think your choice.Sometimes you get a good vehicle sometimes a bad one.ROLL THE DICE..LOL
   / HD F-150 or 3/4 ton truck? #124
All this back and forth seems to reinforce what most of usl thought to begin with - if you buy a truck mostly for towing and heavy hauling and drive a lot, get a 3/4 or 1 ton with a diesel. If you are a more normal user and run the truck unloaded a lot (and a lot of business owned trucks seem to run around empty most of the time) you will come out ahead in the long run with a gas truck because of the lower initial cost and low gas prices. With 3K miles on my ecoboost, I have only recorded about 300 towing miles. I may be on the low side but I don't think I'm that much of an exception.
Also, for those who say their EB didn't get good mileage even unloaded, there must be something wrong. Mine recorded a hand calculated 21+ on the highway at over 75 mph with only 1000 miles on the clock. I expect better when its really broken in.
Down hill all the way ???:D
   / HD F-150 or 3/4 ton truck? #125
I have owned both and the Ecoboost will out pull ten+ year old diesels. It won't hold a candle to the new ones. My problem with the ecoboost was there was nothing eco about it. If the truck is completely stock and empty it gets good mileage. Any load and the turbos spool up and it sucks fuel. My 2012 EB I bought new got horrible mileage especially when towing. I was towing a 18' utility trailer with an ATV and a UTV on it and was getting 4-5 MPG. With a 26 gallon tank if I recall correctly I had to fill up every 100 miles. I went to the dealer multiple times and they could find nothing wrong. They blamed it on my mud tires which were slightly larger (but no lift), my grill guard, and my tool box and air compressor in the bed. I traded the truck. Pretty sad when I was traveling with a 2008 F-250 with the 5.4 gas pulling a trailer that weighed three times what mine did and he was getting double the mileage.
I have a friend with an ecoboost that is bone stock and he drives around with an empty bed all the time. He gets around 20 mpg. I never saw over 14 mpg even without a trailer. I hate the ecoboost. I lost a lot of money buying that truck. I wanted to like it. It was the first brand new truck I ever bought,
Wow!!... the best unloaded mileage on your ecoboost was JUST UNDER what I just got hauling 4 full loads of hay on the 20ft fifth wheel being pulled by my diesel 2003 4x4 Ram 3500
best hand calculated full tank hi-way run 24.4 mpg.
the ride getting hay was rough enough that the wife had to sit on a pillow for the last 2 runs,
these older Ram 1 tons do ride a bit rougher...:laughing:
There had to be something wrong with that F-150...
   / HD F-150 or 3/4 ton truck? #126
I don't know if this is relevant today, but I took off the 16" tires and wheels on my 1990 F250HD which required 80psi and installed new 16.5 wheels with 33x12.50 tires that I run at 45 to 50 psi. This made a HUGE improvement to the ride quality. This was my daily driver work truck and would have been unbearable without this change.
Wow!!... the best unloaded mileage on your ecoboost was JUST UNDER what I just got hauling 4 full loads of hay on my 20ft fifth wheel being pulled by my 2003 4x4 Ram 3500
these older 1 tons do ride a bit rougher...:laughing:
Unfair! You can't buy new pick-ups with a pre-emissions 5.9 Cummins anymore. If you could, I never would have started this thread. The 10+ year old 5.9 trucks that are for sale are going for super high prices for old vehicles with a lot of miles! Didn't want to get something that old but maybe I should be considering it.
I had 315x75-16s on my 1999 F-350 and very heavy springs on the back (heavier than an F350 SRW but lighter than a DRW) and it rode like a sedan. It does make a difference!
Thanks coobie. That's the kind of info that is really helpful to know about. Do you know if that was an 8.8" or the 9.75" rear that you had? What type of towing and how often?
I think he is also referring to the first paragraph of the quote. Remember that the tongue weight is considered payload, and many 1/2 tons don't have that much payload capacity left once you subtract the tongue weight of a large trailer, fuel and passengers.
Thanks, that's probably what he was referring to. Yes, many half tons have crazy low payloads (some Rams are under 1,000 pounds!).
However, this thread is comparing the F150 HD which has a 2,780 pound capacity (GVW minus curb weight) in crew cab, 4WD, "long bed" (6.5 ft). And that is why I didn't understand what point he was trying to make. The GM 2500 he used in his example has less payload (based on his own numbers) than the F150HD. My guess is he was thinking of most 1/2 ton pick-ups and not specifically an F150HD. Many F-150 crew cabs are only rated for 1,300 - 1,500 pounds.
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2014 Toro Workman HDX-D Diesel Utility Cart (A51691)
2014 Toro Workman...
2014 Ford F-550 Altec AT37G 37FT Bucket Truck (A51692)
2014 Ford F-550...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2003 Pierce 75ft Ladder Fire Rescue Truck (A51692)
2003 Pierce 75ft...
