dmccarty
Super Star Member
I have seen strong research by EPRI and DOE that says turning a heat pump off and on during a day actually increases the total electric consumption. If temperatures drop more than a few degrees, the HP will call for expensive electric resistive backup and the total consumption will rise drastically. They recommend just turning it down a few degrees - if you must - but never shutting it off. They actually say running it constantly at the lowest comfortable temperature is the best way to save. Apparently the HP has to be off for more than a full day to have any hope of actually saving.
The heat strips do not turn on when we do this. No way would it be cheaper to run the heat pump all day. Because that is exactly what that danged thing will do, run all day long vs twice. When we turn it on in the morning in might run for an hour or so. Running two hours a day is cheaper than running 24 hours. Our average power bill is $120 a month. During the summer, the bill can jump to $180-190. I expect our heating bill would be over $200 a month. The wifey does not like cold temps so we let the temps get to 82ish in the summer but we keep the temp a max of 72-75 with the heat pump. Last months power bill was $140-150 some of which was heating but I also was using the stove more than usual. I have never seen the heat strip lights turn on and the heated air from the registers is not real hot either.
Later,
Dan
