Heated container
/ Heated container #1
andrehoude123
Just wondering if any of you guys ever heard of or installed a wood stove in a sea container ? We have a camp in northern Quebec and it gets pretty cold for the sleds during winter it be nice to have a warm place to keep them at night and a nice place to work on them when something breaks down.
Just wondering thanks for any information
/ Heated container #2
That should be an easy thing to do as the containers are steel construction so normal clearances are not a problem. Simply cut or drill a nice round hole to pass the stove pipe out thru the roof.
Probably a 10 inch hole for a 5 inch pipe but you will want to have a short length of the larger pipe to serve as a collar and probably more than 12 inches high otherwise water will come in from rain and the melting snow. Naturally the larger pipe will need to be well sealed.
Alternate is to go out a side wall using 2 elbows and then only a simple short length of gutter or eaves trough would stop water from entering via the hole.
The more pipe inside the more heat you will generate, i.e. stove on one side with stack out the other. One problem is the more angles the poorer the draw.
Also in a container being as compact as it is go for the smallest wood stove you can find.
I have seen light weight back pack stoves for those the do winter camping.
/ Heated container #3
Should be easy to do. But be aware that it is going to somewhat ''rain'' in it. As it is an all steel structure, there gonna be a lot of humidity & condensation inside . Nut it sure can be a good alternative up north and it is sure better to work on a sled inside a heated sweaty container than at - 35c in the wind.....
/ Heated container
Ya I was thinking of insulating with 2 inch insulation go try to keep some of that heat when it real cold
/ Heated container #6
Containerized wood chip and wood pellet boiler systems are very popular in Europe and growing in use here in the States, so not only would a simple wood stove work in your container, you should be able to find the exhaust systems including gaskets rather easily. Don't forget that you'll need to install a vent for air supply into the container as well, make sure it is screened or you might find some woodland visitors have moved in while you were out. I'd also recommend using some sort of security bolts/nuts/screws where your intake vent and exhaust system mount to the container so that nobody can easily disassemble it but other than that you should have no problems. Battery powered Carbon Monoxide detector would be worth the expense as well.
As to your insulation issue, before you proceed with the typical home layed in insulation (that miserable pink stuff), you might want to look at the new insulating paint or foam options. Foam would be difficult as in needs to be sprayed (air compressor) but there are paint options that can be rolled on with the correct nap of roller that will work, not quite as effective as sprayed but getting close. The paint option is probably more expensive that the house fiberglass but once it is dry, you wont need to worry about breathing in the loose insulation. Boat owners in the Pacific Northwest and Alaska have been using the paint option very successfully. It also helps with noise although I doubt you have that problem.
Shipping containers are becoming much more popular for remote housing use and I think you'll find a lot of products out there specifically designed for your situation. If you are having challenges finding the correct exhaust system for your wood stove to container, feel free to send me a message with your general area location. I'll see if I can find you a dealer or two to contact. My company just installed a 250kW pellet boiler in a 40' container and the exhaust was no problem.
/ Heated container
Bruce
Can I have an insulated container with out the cooling system?
And ya I totally agree about the fresh air return and if I get one with no insulation it's to be a 2 inch rigid insulation that will also make my vapor barrier 2 birds one stone !
/ Heated container
Oslo flaco I'm in Cornwall Ontario witch is close to Ottawa or Montreal :) thanks
/ Heated container #9
Sent you a pm with details. Sounds like the easiest is a sidewall penetration exhaust due to snow load on a flat roof trying to seep into the exhaust/roof seal. Container roofs flex a lot compared to the standard flat roof which can break the seal if you don't compensate with a welded ring/cap.
/ Heated container #10
Look at northern tool they have lp fishing shack heaters on sale now.
/ Heated container #11
If you want fast, simple heat, something easy to work with. I'd would go with a propane wall heater. takes very little space and you probably can run it off a 20lb bbq tank. I have not tried this though, and I am sure there are many dangers with propane, but it can be the simplest thing. Just make sure you have adequate ventilation.
/ Heated container #12
Just be aware of gas fumes from the sleds ! Wouldn't hurt to have the stove up off the floor a bit for that reason,the fumes will stay low. Make sure you have a good fast way out too.
/ Heated container
Ya for sure the door will stay open when I'm in there !
/ Heated container #14
Propane will create moisture.
Wood and other fuels would be drier but with snow on cold metal roof when you start heating you will probably think it is raining inside.
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2003 GMC C4500 Crew Cab Dump (A62613)
2003 GMC C4500...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
