Heating Ohio pole barn
   / Heating Ohio pole barn #21
Nothing is needed to be changed on the roof.
If you get metal liner panels, just screw them up to the bottoms of the trusses. Metal will span the 4' opening just fine for holding up lightweight insulation. But you wont want to walk on it from the top side. So when doing the insulation, make sure you stick to walking on lumber up there.
Diagonals in the corner are for lateral strength. I usually see them on the outside of the post. Where they are at now....kinda interferes with doing inside walls. But if doing inside walls, those really arent needed.
At this point, the hardest part is gonna be working around all the stuff in there. Trying to do insulation as an after though once the building is already in use and full of tools is a PITA. (pain in the @$$).
I have seen fiberglass insulation done two ways in a "pole barn".
1. You can add your own vertical studs, toe-nailed into the horizontal wall girts, either every 16" or 24". And run your fiberglass vertically just like in a house between studs.
2. You can add a 2x6 studs, horizontally, between the posts....attached to the horizontal girts.....and run the fiberglass horizontally.
What is the current spacing between the horizontal girts now.....would be nice to be right at 24" on center. If you decide to add vertical studs.....price the job as a whole before deciding if 16" or 24" centers is better. 16" is gonna require more studs....so more cost. But most times 16" insulation rolls or batts are cheaper per sq ft. So price it both ways if doing yourself.
A couple of pointers, keep the OSB wall sheathing and insulation OFF the concrete floor. Dont let it touch or it will draw moisture.
   / Heating Ohio pole barn #22
I pretty much agree with LD1. You are fine overhead. The corner bracing is probably a local thing, my pole barn never had it but when I finished it with OSB inside, that resulted in the same bracing function.
Call some commercial roofing/insulation places and see if there is a local source of used roofing foam panels. That would cut down on the amount of studding you would have to add. Those panels are much better insulation than the panels under your roof.
They are 24" on center.
Would this be for the walls? Not quite making out how to go that route...
   / Heating Ohio pole barn #25
Vapor barrier, well tape sealed, is very important especially over fiberglass insulation otherwise humid air will permeate the insulation and you will have 2-3" of frost where you thought you had nice dry wool.
In fact you want the literally be inside of a nice big plastic bag!
   / Heating Ohio pole barn #26
If you can find the used insulation, esp 1 1/2 thick. I would cut & fit them horizontally against the metal & behind the posts, then an additional layer over it all now that your purlins are flush with the insulation. Most of this recycle'd insulation is Poly-iso at 6.5 r value per inch. 3" would make your building easy to heat at near R 19.5! This method will also dramatically reduce or completely eliminate airflow (drafts) through the wall if you caulk or seal the edges with can foam. No additional framing needed for this method.
   / Heating Ohio pole barn #27
I have poles on 8 foot centers, 12 foot ceiling. I put two layers of polyiso sheets, just fitting in the 4 x 8 sheets bringing out the insulation surface to within 1.5 inches of the inside of the poles. Then I added two horizontal 2x4s between the poles (to be able to nail the OSB) and filled in between them with the third layer of polyiso sheets. Then I covered the whole thing with a plastic sheet for a vapor barrier and finished with OSB. Seems to be working pretty well. I should have a total R value of at least 30 in the walls, which is way more than I need. My barn is 2000 square feet and I have a 80,000 btu wood stove. It easily keeps it warm enough to work inside in shirtsleeves with single digit temperatures outside.
   / Heating Ohio pole barn #29
There is a craigslist ad in Columbus for insulation. Rick
Nov 21 INSULATION ROLLS / BOARD & PINK FOAM (COLUMBUS) map
Ha that was just posted. Great find. I would want 1" and half though correct?
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2023 LMC M30018 LOT IDENTIFIER 106 (A53084)
2023 LMC M30018...
2024 KUBOTA KX080-4 S2 EXCAVATOR (A51246)
2024 KUBOTA...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
