Heating problem.
   / Heating problem. #21
blow in some cellulose insulation in the ceiling, as much as 4 inches will make a big difference, the more the better: put a fan in a window, blowing out, and then go around all the doors, windows and baseboards with a damp hand, and you can feel where the air is coming in: caulk them really well; you will see a big difference with just these 2 items.
heehaw
   / Heating problem. #22
TERRY
like i said in your other post,try to put the plentum on the bottom of your furnace,cottage bases are available for the MILLER trailer furnaces,youll see a big difference.ITS hard to warm up a floor if the heats coming out the top.
ALAN
   / Heating problem. #23
Counterflow furnaces sit on top of the plenum. It's pretty hard to take a conventional upflow furnace and convert it to be a counterflow unless its a multi-poised furnace to begin with.
   / Heating problem. #24
TERRYS furnace is a MILLER trailer furnace which is easily converted.He had another thread here on this subject.Its hard to warm up a floor with the heat coming out the top.
ALAN
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
JD 1814E LOT IDENTIFIER 264 (A53084)
JD 1814E LOT...
2010 Cadillac CTS Sedan (A51694)
2010 Cadillac CTS...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
UNUSED JCT 60" HD HYD CONCRETE MIXER (A51248)
UNUSED JCT 60" HD...
