Heavy Trailers & Utility Tractors?
   / Heavy Trailers & Utility Tractors? #11
I've pulled my 3400# camper (17ft) on an 3PT A-frame w/2" ball, all over my property, with a JD 322 - L&G tractor. /w3tcompact/icons/tongue.gif (Just be slow & safe.) /w3tcompact/icons/wink.gif....RayBee
   / Heavy Trailers & Utility Tractors? #12
With my TN75, I've moved my dual wheel flatbed with the 2120 on it. Combined weight must be in the 10,000# region. I hardly notice I'm pulling it. Be careful on hills as the weight will try and push you around.How's your TN. Been having fun making hugh piles of snow with mine.Trailer is Pintle hook and I just pinned it to drawbar connected between 3 point hitch arms. Just keep them low to keep weight down.Andy
   / Heavy Trailers & Utility Tractors? #13
Oh yeah......the moving of the 4500 lb camper.....was with a $19.95 drawbar from TSC with a drawbar lock.../w3tcompact/icons/grin.gif
   / Heavy Trailers & Utility Tractors? #14
hears your trailer
I got this <A target="_blank" HREF=http://www.agshield.com/haytrlr.html>link</A> this morning via email. Tractor guys, it's a wonder they find the time for interest in other things, like to make families......../w3tcompact/icons/laugh.gif
   / Heavy Trailers & Utility Tractors? #15
Morning Ron,
We're busier than a one legged man trying to out run a bare, er, uh, bear!
Life is good, plenty of projects. You need to come by and visit with Lucy. You will like her. She's a little trampy looking, red, flashy, but she is strong!
   / Heavy Trailers & Utility Tractors? #16
Morning Tim,
Yeah, I got the information back there in the idea kitchen cooking. It might take a month, maybe a year, or two, but when it's done....................../w3tcompact/icons/laugh.gif
thanx
   / Heavy Trailers & Utility Tractors? #17
Re: hears your trailer
That is such a great idea! Makes me wish I needed to haul hay bales! /w3tcompact/icons/laugh.gif
   / Heavy Trailers & Utility Tractors? #18
I've pulled a heaped full, 225 bushel capacity single axle manure spreader up a long hill and through a soft field. I have no idea on the loaded weight, but empty the dry weight of the spreader is approximately 3,000 pounds.
I know it was a load. When I engaged the PTO to empty the spreader, the tractor snubbed out. High RPM's and engaging the PTO while rolling in 2nd gear of low range was the only way to make this operation work. Normally this spreader is pulled out behind a large gas engine IH.
   / Heavy Trailers & Utility Tractors? #19
I'm looking to purchase (not make - I don't have the time nor tools) a 3-pt receiver attachment that I can fit my truck trailer receivers into. This would allow me to move the boats, small trailers, and my 10K trailer around quite easily. If anyone can direct me to a manufacturer that has one I'd buy it today. That way I can use the receivers that I have and not have a fixed ball - plus use the 3-pt to raise the trailer up and down when I move it.
Anyone seen such an animal? think of your receiver setup on the back of your trucks (my Yukon Xl has one) and that's what I'm looking for - but hooked to a 3-pt.
Thanks.
-Bob
   / Heavy Trailers & Utility Tractors? #20
rmonio,
Here is a place that sells what you are looking for.
<A target="_blank" HREF=http://www.badriverinc.com/prod02.htm>http://www.badriverinc.com/prod02.htm</A>
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2013 Ford F-150...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2010 Freightliner M2 106 T/A Altec D2050A BR 50ft Digger Derrick Truck (A55973)
2010 Freightliner...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
