Hello to all - it's been awhile! Need some simple info on a JD 2150
   / Hello to all - it's been awhile! Need some simple info on a JD 2150 #1
45er
New Holland 1925
After a recent addition to some land I bought, the former owner left a JD 2150 tractor there and basically said "it's yours". I spent a few hundred bucks and had a tractor mechanic bring it up to snuff. As stupid as it sounds, I CANNOT FIGURE OUT HOW TO RAISE THE "HOOD" ON THIS SUCKER! I thought I was an absolute moron until I asked my neighbor, who is much more tractor savvy than I. He has helped me keep the battery charged and other minor support for the tractor, but his answer was, heck if I know, when I asked him how to do it!
So quickly - what's the secret? Are there bolts that clamp it down? I live 110 miles from its location so I can't run out to the barn and look at anything.
Many thanks!
   / Hello to all - it's been awhile! Need some simple info on a JD 2150 #2
You've a German JD: John Deere: Total built: Mannheim, Baden-Württemberg, Germany: Original price (USD): $17,000 (1986) John Deere 2150 Engine: John Deere 2.9L 3-cyl diesel: full engine details ... Capacity: Fuel: 19.5 gal [73.8 L] 3-Point Hitch: Rear Type: II/I: Control: load and depth control: Rear lift: 2,023 lbs [917 kg] Power Take-off (PTO): Rear PTO: independent : live (with reverser)
Maybe you need one of these: John Deere Model 215-2555 Tractor Service Repair Manual
Ralph
Ralph
All I need to know is how to raise the cowling (hood) or whatever. I dang sure am not going to try to "fix" anything when I can't even open the hood! LOL
   / Hello to all - it's been awhile! Need some simple info on a JD 2150 #4
[video]https://images.app.goo.gl/NZjqf8jb1q46Mcha6[/video]
If this is the tractor referred to the hood may not lift.
   / Hello to all - it's been awhile! Need some simple info on a JD 2150 #5
Access to the engine by removing the side screens (named grille).
   / Hello to all - it's been awhile! Need some simple info on a JD 2150 #6
The hood is bolted on (only one side shown)
   / Hello to all - it's been awhile! Need some simple info on a JD 2150 #7
Not exactly. Each side of engine is easy to access if tractor has no FEL. Removing side screens on a JD 2150 will access frt hood retainers,front of radiator,hyd oil cooler,rear of fuel tank & front hyd pump where destroking screw would be located.
I do sincerely thank you guys for the responses. However, am I being overly critical and saying that building a tractor that you have to remove bolts to access under the "hood" is very impractical?
   / Hello to all - it's been awhile! Need some simple info on a JD 2150 #9
It is what it is... too bad for the inconvenience. Trade up.. ;)
Since I basically got the tractor for free (I have a 1999 New Holland 1925 here on my land), I shouldn't complain, huh? It's just when you're used to one latch to lift the entire hood, this JD is a P.I.A.!
Mini Excavator Quick Connect (A45336)
Mini Excavator...
2025 Wolverine TL-12-72W Hydraulic Rotary Tiller (A47484)
2025 Wolverine...
WANCO 6K LIGHT TOWER (A47001)
WANCO 6K LIGHT...
2018 Ford Explorer AWD SUV (A44572)
2018 Ford Explorer...
2018 Rock Solid 8x28 Cargo Trailer  Generator & A/C, Work-Ready (A46878)
2018 Rock Solid...
2025 Wolverine PT-16-01C 3-Point Quick Hitch (A47484)
2025 Wolverine...
