Hello to everyone bikeguy628 here Newbie in Tennessee
   / Hello to everyone bikeguy628 here Newbie in Tennessee
Thanks so much new hear and not even sure how to negoiate the sight yet.
   / Hello to everyone bikeguy628 here Newbie in Tennessee #12
is it possible it is a hydraulically controlled clutch and it sounds like you may be pressurizing your case through some circuit issue
It's possible I guess,I'm really not sure but i think this tractor is suspose to be a dry clutch type system.Not sure of anything yet got sick with the flu and have not had a chance to do much more then unload it off the trailer after buying it and bringing it home.
   / Hello to everyone bikeguy628 here Newbie in Tennessee #14
Foamy fluid could be caused by water in fluid which has been emulsified.
Suction leak will cause small air bubbles to appear, and mixed with the emulsified fluid, will cause problems.
I would recommend change all filters, use correct fluid. find suction leak if any.
Install a 3000 psi pressure gage in a tee in the FEL IN port to monitor and trouble shoot the hyd system.
UNUSED FUTURE 100YG PIPE CRIMPING MACHINE (A58376)
UNUSED FUTURE...
(2) ROW AULTIVATOR (A58375)
(2) ROW AULTIVATOR...
7ft X 16ft Eclosed Deep South Trailer (A57453)
7ft X 16ft Eclosed...
2011 Ford F250 Pick Up (A55272)
2011 Ford F250...
Enmark X Spray (A57149)
Enmark X Spray...
2000 CASE 580SL II Backhoe 2WD (A59213)
2000 CASE 580SL II...
