HELP 1998 Kubota B1700 HST slips out of low range
   / HELP 1998 Kubota B1700 HST slips out of low range #1
bfdow
Rutland, VT area
1998 Kubota B1700
When I shift into low range, it does not feel like it goes all the way in. I have tried stepping on the HST pedal, no change. When I apply a small load, it pops right out. Fluid and clutch free play are fine. Any suggestions appreciated.
1998, 17 hp, 430 hours
   / HELP 1998 Kubota B1700 HST slips out of low range #2
Not good to diagnose without actually seeing it.Is there a stick or something catching or preventing full movement of the shifter? Is it bent? If not out of adjustment it might be the inner spring (ring/ retainer) on your shifting hub on the inner driven shaft itself. Just a thought. /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
There is nothing that I can see interfering with linkage. How is linkage adjusted? I don't see any threaded rod type of adjustment.
What repair manual would I get for this tractor?
2019 TerraGator 7300 Spinner truck (A56438)
2019 TerraGator...
403 (A52706)
403 (A52706)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
TANK MANIFOLD (A55745)
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
