Scooby074
Super Member
Ahh.... you would be surprised at how well brush does not burn.
:thumbsup:
I'm in total shock!!! I sure have learned something today. I was a boy scout. I sure thought a lot of other were too. I've never thought of using anything but old newspaper, cardboard, and small branches. It takes just minutes to start a good fire, so what is the purpose of using the petroleum products??? I really had no clue so many people used them. Stay safe people.
Yeah, it is water. A dry pile of size can light so well its dangerous. A wet one will light, smoulder, and go out. Size is your friend with a damp pile. Get as much burning as quick as possible on the windward side. With luck you get enuf burning to dry adjacent wood. Thats why a big torch is good. You can help it along a little til its self sufficient -- then when its burning strong enuf, push it around a bit with the FEL to influence the burn.Ahh.... you would be surprised at how well brush does not burn.
K Mr. NY Boyscout, lets see you start one here on a typical spring day. 40 degrees, raining, and blowing 35 knots, U probably only need one match and a good whittling knife to try to get some dry wood out of the beach logs. I will use whatever I have to get the job done personally.
Rick
few gallons of used motor oil on hand needing to be disposed of, so why not use them.
Used motor oil has heavy metal contaminates it it. So, don't put anything on the fire you don't want in your soil. Even gasoline leaves a residue. May not be much, but enough for the chemists to measure it.
