Help a newbie plan for planting grass next spring.
   / Help a newbie plan for planting grass next spring. #11
All of the open grass areas I planted with a tow behind spin spreader using a lawnmower to pull. I have a larger 3pt spin spreader but it isn't needed for small areas such as lawns.
A small tow behind spin spreader is what I recommend since you can use it to fertilize your lawn as needed.
I'll probably do that to start out, as I said the lawn mower will do much less damage pulling it around :)
May use a 3 point once the food plots get bigger.
Picked up a 7' rear blade for it today, we have frost so I won't get to move much other than to level some gravel that hasn't frozen.
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
1999 Ford Ranger Pickup Truck, VIN # 1FTZR15X6XTA79787 (A51572)
1999 Ford Ranger...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
