HELP!! a simple way to remove the husk off of walnuts fresh from the tree???
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
My wife spends a lot of time cleaning these. She uses a knife and had wire brushes them.
How do you clean them?
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #2
Put them in the driveway, drive over them with the cars until the husk comes off. Let them lay until they dry and then pick them up and put them into a bucket until ready to crack.
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #3
X2...
Doesnt the weight of the trucks break the walnut shells??
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #6
Experiment with the idea. You could use a small car instead. Once they are dry I used to crack them with my fist against a hard surface. Just lay the walnut down and give it a good sharp crack with the bottom of your fist. I wouldn't recommend that method for high production numbers though.
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #7
Depending on type of walnut. English walnuts tend to be thinner shelled and easier to crack. Black walnuts can be about like trying to crack a rock.
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #8
ware gloves!! I have drilled a hole in a 1x4 the correct size, then I just push them through. The bit on each end wipes away easy.
I don't like have a driveway full of husks. nd you leave them to long and the squirrels get them
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #9
If you have turf tires on your tractor just make a shout as wide as the tires, jack tractor up 1 1/2" and shove the nuts to it. You can't feed it fast enough.
   / HELP!! a simple way to remove the husk off of walnuts fresh from the tree??? #10
My grandfather taught me the hole in the board method. He drove the nuts through with a hammer. I suppose you could have several holes of different sizes.
2012 Ford F-350 Mechanics Service Truck (A48081)
2012 Ford F-350...
2009 Chrysler 300 Sedan (A48082)
2009 Chrysler 300...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2019 PETERBILT 348 TANDEM AXLE 22FT REEFER BOX (A50505)
2019 PETERBILT 348...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
