Help and knowledge 68 JD400 injection pumps
   / Help and knowledge 68 JD400 injection pumps #1
Oldchevyguy
1968 John Deere 400
Hello I have two JD400 backhoes one I’ve had for almost 3 years and one I just bought hopefully to make 1 really good machine out of two. Neither Is running, both are having injection pump issues . Firstly I’m having a hard time removing the pumps both are CDC type which I’m learning are the red headed step children in the Deere injection pump family. So far I have all the lines and linkages disconnected as well as the two nuts holding it to the gear housing and I’m figuring out I must have to take off the inspection cover and do something in there . Any advice or direction would be appreciated. After that I’m struggling with the issue of finding someone who can work on it. Does anyone know an outlet that can service this CDC type pump? Next I’m wondering does anyone know about an upgrade or changeover that can be done? I guess Deere offered a kit at one time that’s also discontinued. Is there some kind of workaround for this or do people just scrap the machines when the pumps go bad??! Please any help or advise will be greatly appreciated as well as if anyone has or knows where to get parts to fix or update this tractor.
   / Help and knowledge 68 JD400 injection pumps #2
Check with someone BEFORE you remove the pump. IDK about the CDC pump, but removing the Roosa Master pump without timing the engine leads to a huge job of timing the engine to the pump.
   / Help and knowledge 68 JD400 injection pumps #3
Old Chevy Guy.. send me a prvt msg and include your home email.. so I can send you a couple of pictures..
In the meantime, bolt the pump back to the block..
I’ll show/tell u how to time it.
   / Help and knowledge 68 JD400 injection pumps #4
The pumps won’t come out because they’re still attached to the drive gear..
U have to gain access to the front of the pump..
There’s 3 Allen head screws that have to come out from the drive shaft..
BUT.. u have to time it first..
I set the timing before I started. Pm sent
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
New Holland T2420 (A53317)
New Holland T2420...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
2019 INTERNATIONAL LT625 SLEEPER (A59575)
2019 INTERNATIONAL...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
