Help choosing a water pump for burn pile safety
   / Help choosing a water pump for burn pile safety #1
muckdp
California
2010 Kubota M5040HD
I have a number of burn piles I need to do this year. Gubberment regulations, and common sense say that I need to have a water source nearby, but unfortunately I don't. I have a Kubota M series, and a 250 Gallon pallet tank (like one of these: 250 gallon liquid shipping container tank ibc lot of 52 ), but I don't have a good way to be able to spray the water from the tank. I've tried reading through some pump information I find on the interweb, but I'm not clear what exactly I need. Here are my basic specs, and hopefully someone can fill in the blanks for me, and point me in the right direction
* Should behave roughly the same as water from a standard water spigot ( which I believe is in the 50-60 PSI range) when run through a garden hose. Both in terms of water volume, and in terms of "spraying range".
* I'd prefer to be able to just drop the "suction" hose down from the top, instead of having to connect to the valve on the pallet tank.
* Preferably would use 120v or 12v electricity, instead of being a gas powered unit -- I'd rather hook this up to my existing gen set, or to a pair of batteries, than have to maintain yet another gas motor).
* Being able to leave the pump running, and having the trigger from the garden hose sprayer be the "on/off" switch would be great -- but not a necessity.
* I'd like to keep the cost under $300 if possible.
I realize I may be way off base here, and I'm sure I'm not using the proper terminology, so I'm hoping someone can point me in the right direction.
Thanks in advance!
   / Help choosing a water pump for burn pile safety #3
I don't know which pump, but I know it will work better to draw from the valve at the bottom. The gravity will work much better with no head pressure.
I need to set up the same rig. Maybe a pto pump is the way to go...
Sure flo makes a good 12 volt rv pump for under a 100.
It will auto shut off, but only enough for a garden hose.
   / Help choosing a water pump for burn pile safety #4
I am sure you can not dead head this with closed nozzle but switch on electric when needed. Ten minutes would empty your container. I use one and like it but pump housing needs prime. If set below tank simple on/off switch as long as outlet is above tank.
Portable utility pump with up to 120 ft. lift capacity.
■Max. flow rate: 1500 GPH/25 GPM
■Powerful 800 watt pump motor
■Brass standard water hose connections
■Cast iron pump body
120 volts, 60 Hz, 8.4 amps
Portable Utility Pump - Save on this Portable Utility Pump
   / Help choosing a water pump for burn pile safety #5
Get yourself a PTO driven pump, like this one: Hypro Pumps Roller Pump, 5 Rollers:: Cast Iron, Less PTO Coupler - Dultmeier Sales
You can get them in various gallons per minute and psi. I bought this one this week to suck water out of my picking bins.
If you decide on one of these, make sure you also buy a PTO coupler, the company in the link above sells it too. The y also sell the hose fittings and screeners that go on the end of the sucking hose.
You'll also need to attach a small gauge chain to the pump and hook the other end on something sturdy (like your tractor's drawbar), to keep the pump from spinning when you engage the PTO.
   / Help choosing a water pump for burn pile safety #6
I have a PTO pump, an 1 1/2 inch gas and a three inch gas pump. When I light fires in areas that I cannot reach with hose and one of the gas units I use the smaller gas pump and a tote to provide emergency water -- it provides plenty of pressure and volume to control the fire. In most cases the PTO pump gives lots of pressure but not much volume. The 12 volt electric pumps that I looked at just did not seem to pump enough to control an emergency. I do not have a genset so I also steered away from 120 volt pumps. Maintenacew on the gas pumps is pretty minimal -- making sure they are drained before winter is the biggest PITA
I usually also cut a line around the pile and wet it with a sprayer prior to starting the fire. Once the fire is going I use hand sprayers to control sparks.
   / Help choosing a water pump for burn pile safety #8
Oops, missed the part of your post that says home type results would be fine.
I would suggest a Shurflo RV type pump, something like this.
Classic Series Water Pump - SHURflo
I've installed 2 of these in my campers and have 3 other friends that have done the same. Good pumps.
And you'll have 'at home' type results.
   / Help choosing a water pump for burn pile safety #9
I'm sure your gas pumps do well.
Generally PTO pumps, depending on how much you want to spend, can do 0 - 300 gpm; real firemen use these babies PTO Pumps, some of which can do 1500+ gpm.
Since the OP said he was using a 250 gal tank, I suggested something that wouldn't run it dry in less than a minute.
   / Help choosing a water pump for burn pile safety #10
Then I'd say the simplest solution is a submersible well pump. A pressure switch will keep the pump from running when no draw is required. Yet your hose would be pressurized with water on tap instantly. Connect a hose and wire, drop it into the tank. Start your genset. If you had two tanks, you could easily switch to your back-up tank.
2011 Cadillac SRX LUXURY (A50324)
2011 Cadillac SRX...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
2012 John Deere 7230R (A52128)
2012 John Deere...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
