HELP I NEED Jacobson center deck pully for HR 15
   / HELP I NEED Jacobson center deck pully for HR 15 #1
randy111
ravenna ohio
jacobsen hr15
Does anyone know where i can get a center deck pully for a Jacobson HR 15 Jacobsen part #163716
It appears jacobson does not make anymore.
Thanks Randy
   / HELP I NEED Jacobson center deck pully for HR 15 #2
Randy, are the splines alright on the pulley? If so, a machine shop could weld into a new sheave. Likewise, if the splines are bad, count the splines and measure the shaft diameter to determine a replacement that could be welded in the sheave.
   / HELP I NEED Jacobson center deck pully for HR 15 #3
Thanks Randy
If the pulley grooves are still good, the center splined area is replaceable from Jacobsen. I just bought 3 of them a month ago. I can get you the part number if needed.
   / HELP I NEED Jacobson center deck pully for HR 15 #4
Can you forward the part number for Jacobsen Mower Drive Pulley center spline replacement?
Thanks,
DJ in Maryland 301-247-2193
   / HELP I NEED Jacobson center deck pully for HR 15 #5
Thanks,
I have an early serial number between 1601 and 3700. The pulley part number is 163252(obsolete), the center spline replacement is # is 337998. If you have the later machine( serial # 3701 and up) which uses the 163716 pulley, it uses a different spline. I think it is 338701 but Call Jacobsen Technical at 1-800-848-1636 and they can look it up and verify.
Hope this helps.
2018 Ford F-150 (A51039)
2018 Ford F-150...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2014 GOOSENECK DRIVER SIMULATOR TRAILER (A50854)
2014 GOOSENECK...
