Help identifying hydraulic fittings. JIC and ORB
   / Help identifying hydraulic fittings. JIC and ORB #22
How about buying hoses with the right ends instead of adapters?
Surplus Center
Surplus Center
Joe, since his equipment has SAE Straight Thread (ORB) ports, none of the hoses shown on the pages you linked to would connect directly to those ports. All of the hoses shown in your linked pages have JIC, NPT or ORFS fittings.
There are hose fittings with male ORB threads, but not very many pre-assembled hoses available with these fittings. One would have to either have a custom hose made to their specifications, or use an adapter as the others have discussed here.
The combination of JIC female swivel hose fittings and adapters (commonly available in JIC x NPT or JIC x ORB) is very popular and even recommended for many applications.
   / Help identifying hydraulic fittings. JIC and ORB #23
On the fitting in this ebay listing. (20) 6400-08-08 Steel Hydraulic Fittings 1/2" JIC x ORB - eBay (item 380171052459 end time Dec-17-10 14:07:42 PST) Which is the JIC end and which is the ORB end? I'm assuming the ORB end is the one with the Oring? But not sure.
Thanks
Chad
Since I'm responsible for that listing, I guess I can answer this question as well as anyone. :)
The ORB stands for "O-Ring Boss" and is also known as SAE Straight Thread, which many users shorten to just "SAE." This thread is usually identified by (you guessed it) the O-ring that sites between the hex nut and thread.
Here is something everyone should know about JIC and ORB fittings. Their nominal size usually does not refer to the thread diameter. Most people who work with hydraulic fittings will identify them as 1/2" or 3/8", etc., according to the tube, port or pipe for which that fitting was designed.
For example, JIC 37 degree flare fittings were originally designed for connecting metal tubing. As such, the nominal size of a JIC fittings refers to outside diameter of the tubing. In a similar fashion, 1/2" NPT fittings refer to inside diameter of the pipe.
Just so you don't think I'm crazy, you read that correctly. Tubing is identified by OUTSIDE diameter, while pipe and hose are identified by INSIDE diameter. That can be a little confusing in the beginning, but once you commit it to memory, you will have a much easier time identifying materials.
The actual thread diameter will always be a bit larger than the nominal (tube or pipe) size. Using the eBay listing as an example, the fittings are identified as 1/2" JIC, and can be used with 1/2" tubing, but don't be fooled. These fittings have a 3/4-16 UNF thread.
When someone tells me they want a 1/2" fitting, I always ask them to clarify whether they are referring to the tube size or the thread size. It is very important to remember this when you are specifying fittings.
We have a thread size reference page available at DiscountHydraulicHose.com.
This page currently only shows data for U.S. fittings, but I plan to update it soon with threads from Europe and Asia as well.
   / Help identifying hydraulic fittings. JIC and ORB #24
Good info HHG. I edited my post above based on the info you gave me in the PM;)
Thanks everyone. I found the correct adapters for my hose to fit the valve at Orscheln. I also picked up one cylinder there. This way I can measure out and weld up all my brackets for the rest of the cylinders.
I figure I'll buy one cylinder at a time "Money Permitting". lol
Chad
   / Help identifying hydraulic fittings. JIC and ORB #26
Chad,
Have a look at Hyspec cylinders. I just added one to my rear blade. One of the local hydraulic shops commented that they were a decent cylinder for the money (not the place I bought it from).
It was 30% less at an actual hydraulic shop than Princess Auto (our version of TSC or Harbor Freight).
Sean
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2003 International 9200I (A53317)
2003 International...
UNUSED FUTURE...
