Help My TC40D
   / Help My TC40D
Well, believe it or not, yoke shaft 24 broke right in the middle of the cam plate. It's welded super to the outside, but with a little wiggling, I can slide the pedals/shaft out far enough that the inside portion of 24 came out of the cam plate.
Who'd a thunk :eek:
   / Help My TC40D #12
I think I'm gonna cut a bigger hole and weld it while it's on, rather than try and take it off.
Thanks for your help.
I think you are onto something! An access plate under the rubber mat would be terrific, especially since the shaft goes through the B-plate at the top. That should work just fine.
BTW: When you cut that hole, be prepared for finding the whole bottom of the platform is rusted. It seems to be a common thread amongst owners that we all see great chunks of paint and rusty metal coming off in sheets under that platform.:mad:
   / Help My TC40D
Yes, an access plate should be there, and by jove! there's one there now:D
Only it's called a hole!
Weird where it broke, right inside the "B - Cam" plate.
I had a friend with a plasma torch cut it out, had to do a little sawsall work, and careful not to hit/burn the wire harness that runs under there, and then some welding (aprox. 75% around), re-adjust the neutral eccentric a smidgen, and we're on the go again.
It wasn't rusty top or bottom.
   / Help My TC40D #14
That is too cool for words. Great job!:)
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51691)
2019 Ford F-550...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
