Help needed for new Finish Mower Tires.
   / Help needed for new Finish Mower Tires. #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I have a used 7ft Landpride Finish Mower. When I bought it, there was two flat tires. I had them fixed, but have had several more flat tires with it. Most of the problems are dirt around the rim and the seal breaks. I've tried just going forward, but that's not practical in allot of areas.
Yesterday, while mowing, I noticed that part of one tire had shredded. I figured that it was toast, so I just kept on mowing. You can see in the picture what several hours of mowing with it has done. :D :D :D
I'm not going to put anymore money into tubes or repairs. I want to replace all four tires with solid tires and new wheels. I've looked in my catalogs, but can only find replacement tires and tubes. The solids are all allot smaller, which I don't want. I like the width of the tires, which allows them to float to some degree over the ground when it's wet.
Current tire size is 13x5.00-6
I'm assuming this means the tire is 13 inches tall and the rim is 5 inches. Does the 6 mean that it's 6 inches wide? There is a bolt that goes through the middle that mounts the wheels. I grease this with a fitting that's in the wheel.
Wheelbarrow tire and wheel combinations look similar, but I'm worried they might not be strong enough for what the finish mower goes through. Maybe they are?
Does anybody know a source for replacement, solid tires of this size?
Thanks,
Eddie
   / Help needed for new Finish Mower Tires. #2
It's 5.00 wide and the wheel is 6".
   / Help needed for new Finish Mower Tires. #3
The tire size is variable because you can set the gauge wheel heights with spacers. TSC has solid rubber and filled replacement tires to substitute for the air filled ones. Maybe the other option would be to put a shield (chains?) on the discharge to prevent the shredded material from hurting the tires.
   / Help needed for new Finish Mower Tires. #5
Eddie, I had the same problem with a piece of crap King Kutter I bought at TSC. Worst money I have ever spent. I had a tire do the same thing in the first 300' I mowed with it. Over the 4 years I owned it I put $800 in parts not to mention all the frustration and time lost. I have since replaced it with a Caroni, no comparison. It has solid tires. Anyway I got all new tires, wheels, ect from Northern Tool for the KK. They did not show them in the catalog but do a search on the site and you will find they have tons.
As said before your tires currently are 13.5" tall, 5.00" wide, and mounted on 6.00" rims. What is the most important is the spindle dia. I am guessing it is either 1/2", 5/8", or 3/4". You need to get this figured out first. Here is what I put on that KK. It may be a little small for your mower, mine was only a 6' model.
Lawn Mower Style | Flat Free Wheels | Tires + Wheels | Northern Tool + Equipment
You many not find the same height tire but as mentioned before you can adjust the deck height as needed.
Chris
   / Help needed for new Finish Mower Tires. #6
Just took a look at Landprides web site and it looks like they have gotten away from the pneumatic tires all together, smart move. They have went to a solid tire the same size as the one I posted above. I guess that is a industry standard now. I would look at making them work.
Going from a 13.5" tire to a 9.00" tire will only result in a 2.25" loss in mow hight. You should be able to make that up with the adjustment shims used on the spindles. You will have to shim out the difference between the 5.00" width and the 3.5" width, but hey you are a smart guy and will figure that out.
Chris
   / Help needed for new Finish Mower Tires. #7
Chris
Industry standard?? That's pretty optimistic.
   / Help needed for new Finish Mower Tires. #8
You could have all four tires filled with foam. No more worries.
Solo
   / Help needed for new Finish Mower Tires. #9
I have solid tires on my Landpride finish mower. I emailed Landpride and talked with my dealer because the solid tires are too narrow for my sandy soil. They do have the option to go with pneumatic tires if you wish but they are only 1/4 of an inch wider than the solid (if I remember right). If you do go from a tube tire to a solid tire, you may have to change spindles, etc. May get expensive.
   / Help needed for new Finish Mower Tires. #10
Thanks,
Eddie
Eddie, what model is that mower? Landpride has that size semi-solid tire and wheel listed in the parts manual.
Thank you everyone for your suggestions.
I'm fine with smaller diamer tires, and maybe even a slightly larger one. What I think is important is to have as much width as possible. The wider the tire, the more floatation that I'll have.
The problem with the tires is that they are just old. Probably very old. There is no model number on my cutter anyplace. I have a serial number on a metal tag, but that's all I've been able to find. When I ordered new blades, all they needed to know was what size mower it was.
The axle that the wheels ride on is a simple bolt. I can get any size bolt through McMaster Carr, so that's nothing to change axle size.
I've gone through all 16 pages on Tractor Supplie's website without finding a good match. I'll go to the store this week. There is an Atwoods real close to Tractor Supply, so I'll go there too. Probably have better luck at Atwoods anyway.
I did a search on Norther Tool's website, but only found the smaller/thinner tires and lots of wheelbarrow wheels. I don't thing wheelbarrow wheels will work, but don't know for sure.
I'm not in a rush for the tires, I'd just like to take care of it before I need to mow with it again. My 6ft Landpride Rotary cutter is sitting there and I'll use it pretty soon for my really overgrown areas and some rough areas that I would scalp really bad with the finish mower. Does anybody know if a tail wheel off of a rotary cutter will work on a finish mower?
Thanks,
Eddie
   / Help needed for new Finish Mower Tires. #12
Looking at the pic I bet you could come close with other brands. Looks close to my Woods FM. It has a 10" solid rubber.
I went to Tractor Supply yesterday and didn't see anything that might work. I measured my tires and they are right at 12 inches in diameter. I know they are stamped 13x5.00-6, but maybe it's like lumber. You say one size, but the real size is one smaller? Anyway, the inside distance between the metal to mount the wheel is 6 3/8 inches. I can fudge this a little bigger or smaller.
So far, I'm not seeing anything that I think will both float over the ground, and hold up. Most of the solid wheels that I've seen don't have zirk fittins, or are on platic rims. Allot of them are also very thin, of way too small in diameter.
I might go to Northern Tools store in DFW Sunday if things work out with Steph and her plans for the weekend. There is also an Atwoods in town that I want to check out. They always seem to have allot more selection then Tractor Supply.
Thanks
Eddie
   / Help needed for new Finish Mower Tires. #16
Eddie,
Have you emailed Landpride to see if they have what you want OR are you trying to save cash? I am sure Landpride will have what you need.
Ray
Ray,
Interesting idea. I went to their website and looked around, but didn't see anything, so I moved on. I never thought to actually ask them. Gotta wonder how I get anything done some times. LOL
Thanks,
Eddie
   / Help needed for new Finish Mower Tires. #18
If you find a wheel that is too thin, but good in other areas, you could mount them as dual wheels.
   / Help needed for new Finish Mower Tires. #19
CurlyDaveIf you find a wheel that is too thin said:
Now you are talking Dave. Eddie that would be cool looking to! Maybe tough to fab up. I had a spindle that was bent on my Woods, Just a slight bend, but the wheel wouldn't track straight and would dig in sideways. I tried every angle to bend the spindle mount, no luck. Once I replace the spindle, it was fixed. I have some sand in the yard so it was a good fix.
   / Help needed for new Finish Mower Tires. #20
I have a set of solid "hand truck" tires on mine, curly dave stole my suggestion!!!!! I was reading along read what eddie wrote about too thin, thought well get 2 and boltem together. next thing you know there goes dave stealing all the glory!!! Isnt it funny when you concentrate on a problem and a simple answer is right in front of you but you cant see the forrest for the trees.
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
