help pick next tractor
   / help pick next tractor #11
I have narrowed my choices down to 2 tractors that I can afford. My tractor I am upgrading from is a tc 29d . I really like The Tc 29d But it's just too small .I do a lot of loader work with the forks on . Mostly doing rock landscape work .The framer next door gives me all the large rocks I want but some of them I wind up dragging and pushing. So to get to my choices. Tc45d or a dk45 se. I wan't a tractor that has hydro side by side peddles. Nothing with computers or pollution control My tractor sleeps outside. My problem comes from the Kioti has a better lifting capacity.But I think the NH has better build quality. Also I realy like the sloped loader design on the NH. The other thing is that the Nh was built from 98 to 2009 there are a sh t load of them out there . When I look for the kioti they are far and few in between. I have seen videos of the Kioti picking up 2500 lbs . pretty impressive . I know the TC payload is 1600 Lbs. but is that to full hight? Can the DK be really 1000 LBS. stronger or is it more like 500LBS. If any one has made a similar upgrade let me know what u think .Thanks.:drink:
My 2013 DK45SE HST Cab will lift 2765lbs to full height....the engine is all mechanical...injection and governor...: with a throttle cable.. .and a muffler, awesome tractor:thumbsup:
This was the last year of the mechanical ones.
Again thanks for replies.:thumbsup: Qapla L 39 Is not hydro. L 48 has treddle peddle. M59 sweet but way out of price range. Only want used pre 2010. Do you still have tc 40 ? How is the lifting capacity with forks ? Is the woods bh 70 mounted to it? How do you like the Tc 40? 2nd half Did not like loader stick position I want one that's down next to seat not on loader frame. Grm 61 Is their any pollution s t on your DK 45 SE? How do you like the overall build quality? I like Kioti's all mechanical levers where others use buttons and wires and computers. Mice and corrosion don't chew through them as easily.Poor baby sleeps outside. Doesn't matter even in barn mice get in.:mad: Have you ever had an experience with a NH TC series? Just wondering how they compare? I think Shibaura made tractors had excellent build quality and are very easy to work on very well engineered . Thanks again for all help:cool2::drink:
   / help pick next tractor #13
No computer, no exhaust treatment, The build quality is very good imo the DKSE series are a deluxe tractor. The 4x4 and pto are engaged with a switch if that scares you?.
Good luck.
FYI The DK40, 45, 50, SE series with the KL401 loader all lift the same, and need to be properly ballasted to lit max weight safely, the factory calls for 1200lbs on the three point
No fear with 2 extra wires :eek: Just don't like to see buttons and rocker switches all over the place .I have a simplicity legacy and I have been through the wireing on that so many times it makes me sick.:mad:.Just about every f!@#$%n thing has been replaced . Switches and connectors go every year or so when I change from plow to mower deck. It's always a mistery what's going to go this year. Thanks again:drink:
   / help pick next tractor #15
You're on the right track wanting to get into a frame size that you can get some work done, a cab with heat and AC, keeps the weather away from you, and your switches, think about it, buy once:drink:
The cab has always been the great debate .Would love one but I would have to do some serious pruning to get into parts of my yard . Seems that lots of times I am working directly under trees. Gives me a good excuse to go out and buy the pole saw I always wanted .:thumbsup::D I was checking weight and it seems that the kioti weights 700 LBS. more than the NH. But the rear lift is pretty much the same. How do you like your backhoe ?I have been reading about problems with cracks in frames on some models. That much extra weight it must be built heaver duty some where. Front axle must be heaver duty too. Larger front tires on the DK. I 'll have to have to find one and check it out but they seem to be like hens teeth around here. Friggen Kubota heaven. Wish I could find a Kioti dealer close.Thanks again.:drink:
   / help pick next tractor #17
. . . . . I was checking weight and it seems that the kioti weights 700 LBS. more than the NH. But the rear lift is pretty much the same. How do you like your backhoe ?I have been reading about problems with cracks in frames on some models. That much extra weight it must be built heaver duty some where. Front axle must be heaver duty too. Larger front tires on the DK. . . . .:drink:
Oh no! I am thinking of buying either a DK or NK series Kioti with a backhoe and have not heard about the frame crack problem. Is this a wide spread issue or has it been corrected by Kioti? Thanks.
   / help pick next tractor #18
I read a post along time ago where a guy had cracked the backhoe subframe....I have used mine a lot and not had any cracking
2019 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
Honda utv cart (A56859)
Honda utv cart...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
