help please truck with little heat when temp below 20ー F
   / help please truck with little heat when temp below 20ー F #21
JoeL4330 said:
I can't recall if you said you had confirmed that you had anti-freeze protection for the temps you are experiencing ...some symptoms could be ice-dams/ice expansion ...and, when you yank the thermostat, and idle it, look for bubbles in the radiator (hoping you don't find these) that might point to head gasket failure.
Had the bubbles with mine. Smelled strongly of exhaust. Mechanic wanted 2500 to do heads. Ended up with a new motor 3yr/100k mile warranty for 4k in 2009. Still driving it today.
   / help please truck with little heat when temp below 20ー F #22
I would start with thermostat and then go to heater core.
Well the front cover/ timing cover seal is 100% common on the 1997 to 1999 ford f150 with a 4.2 v6. My truck has 126xxx miles and runs great. Hauled a 6x12 u haul loaded down with no issues. always gets good gas mileage.
As I belong to a ford truck forum I found out the timing cover is something every 4.2 owner experienced when the truck was new. Its either never been replaced or not been replaced right. When viewed from the front of a 4.2 liter the engine leaks at the 8:00 position.
A little history on the truck, I owned a 1998 mercury car, and at 200,000 miles the engine locked up due to a clogged pcv valve. My father for my college graduation gift and one year being at my full time job as a truck mechanic gave me his mothers old car. She passed away a few years back. a 2001 Saturn with 75k. The automatic transmission was giving me huge trouble (it shocked me horribly) after going through everything and all my options I had the transmission rebuilt at 1900$. March/ april 2013, while driving with my puppy down the interstate I was passing a semi truck and the dog ran through my arms I lost control. the passenger fender of my car got hit by two semi truck dual tires, I spun out and the back end of my car hit the ICC/ crash bumper I lost steering because of my engine being moved one foot over to the drivers side and was headed straight for the median. Hit the median with a lot of force but was wearing my seatbelt the entire time. I lived with no injurys, the dog is still with me today living strong and I was very thanfull to be alive!!! Borrowed my mothers car for a few weeks and got a 1500$ loan to buy this truck for 2000$ 120,000 miles on it. I purchased the truck and redid the brakes that were GONE and repaired other things. I haven't a doubt in my mind the engine will last as long as I get that timing cover seal replaced asap. I have not a lot of extra money the entire issue is finding a friends house with a enclosed garage to repair everything. I have all the tools and experience needed. I am in the middle of trying to purchase a house now.
But yes search 4.2 timing cover leak on google you will be surprised! They all start leaking at one time or another.
Truck has new coolant in the cooling system. Distilled water and antifreeze 50/50 for a protection level of -34 degs F. antifreeze was changed when I went to stop leak the engine as I have no other vehicle to drive. I drive my girlfriends car when I can as well live together but she is a full time college student and needs her car
   / help please truck with little heat when temp below 20ー F #24
Sounds like it is a sticky thermostat. My Subaru was great until my thermostat was changed routinely. Then, I get sporadic overheating in cold weather. :confused2: Operates fine in the warm. Two layers of burlap in front of the radiator fixed it right up. Also, verify full coolant and correct overflow level and suckback as it cools.
larry
Yes, I just want to get the timing cover re-sealed before I get a lot of coolant in my oil. If that randomly happens I could damage main bearings in a hurry at the least. Even spin one going down the freeway. Anything can happen if I don't fix this the right way
   / help please truck with little heat when temp below 20ー F #26
In cold weather climates, cardboard is a common fix for this. I lived in MT, and never had an issue with it, and the truck ad an exterior oil cooler as well....no elevated temps on either the engine, or tranny. I would probably pull the cardboard for any towing work, but that's about it.
   / help please truck with little heat when temp below 20ー F #27
If you have stop leak in your radiator system then that's probably compounding your problems. It's possible that it's partially plugging up your heater core. I would suggest fixing the leak correctly before flushing the radiator.
Rodger that! The plan is to fix everything in one project. While the front cover is off I will be doing the timing chain. Truck has 126xxx perfect time to do one. Timing cover seal, timing chain, water pump, new hoses, belt and tentioner, and a serious flush. I might even use dawn dish soap. We will see. I want all stop leak and old antifreeze/ sludge out of the system. Thanks again for all your help TBN
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2011 FREIGHTLINER CORONADO (A55745)
2011 FREIGHTLINER...
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
