Help tapping into HYDRO Kubota b5100
   / Help tapping into HYDRO Kubota b5100
Okay so I知 running into a slight issue, what kind of adapter would I need since it痴 a 1/2 shaft on the pump, and I believe it痴 a 1-1/2 inch on the crankshaft of the tractor. Would i need a step down adapter?
   / Help tapping into HYDRO Kubota b5100 #22
Can you post a picture of the shafts on the engine and pump?
What are you going to use for a tank for your pump?
Aaron Z
I send some pics, I did measure and I was way off it is a 5/8 inch shaft so ill probably end up using a love joy. My res will probably be built into the upright or a external tank mounted to the upright
IMG_4766.JPG This is the Front crank PTO that I would be attaching to I counted the splines and theres 21, I'm really not sure how to attach the pump to this originally I thought lovejoy coupler, but I cant get on in the 21 tooth
   / Help tapping into HYDRO Kubota b5100 #25
Many of the early model B series had crankshafts with a splined stub protruding out from the front of the engine.
The issue is finding a female fitting with the same spline diameter and number of splines. There are part numbers to connect a front pump but no one has been able to find these parts for years.
70050-00056 Roller Chain Times 2
70050-00110 Sprocket Shaft
70050-00111 Sprocket W/18 - 22 Spline
70050-00112 Sprocket W/9/16 Bore
Another owner said this:
I am going to look into the Fenner shrink disk. I don't care that I use OEM parts. There is space for another pulley if I wanted to use a 2nd pulley. But the Fenner product seems to be designed for this application. I'll research how to do a s/d. The shrink disk has a collar with several screws that when tightened compress a sleeve around a shaft without the need for a press ( removing the crankshaft etc ).
Suggest you look at the pictures in post # 8 of this link. Gives you an idea of how the pump is typically connected using a short shaft and two couplings, one at each shaft end.
https://www.tractorbynet.com/forums/kubota-owning-operating/175382-kubota-b6100d-front-pto.html
Dave M7040
   / Help tapping into HYDRO Kubota b5100 #26
What is the spacing on the 3 bolt holes? Would a Massey flange mount such as: https://www.ebay.com/i/324017895067?chn=ps bolt up with some spacers?
5-1/4" Diameter with 3 Bushings
Mounting Holes 3.465" on Center
4" Bolt Circle
3/4" Left Hand Threaded Center Hole
Aaron Z
Its possible that that could work, I'm not 100% on the size, I was checking out the fenner disk, I'm almost temped to put a coupler on it and put a weld on it i really don't want to do that honestly, I have plenty of time as I have just ordered the steel to build the loader.
Looking at the Pictures there Dave said to look at it looks fairly simple, A sprocket coming off the crank and a sprocket off the pump with a double chain, trying to find a sprocket that fits on the crank shaft may be a challenge this is where its tempting to weld it on the shaft with a sprocket that slides on unless I can find one that fits i really would hate to weld it
   / Help tapping into HYDRO Kubota b5100 #29
The double chain is actually part of a flex coupling in the drive line to take up any misalignment white still transmitting power.
You buy them as an assembly which includes the double chain.
Couplings for Roller Chains - U.S. Tsubaki
Dave M7040
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2020 DRAGON ESP...
2018 Dodge 5500 Bucket Truck 4WD (A56438)
2018 Dodge 5500...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
John Deere Z997R (A60462)
John Deere Z997R...
