Help! Three point hitch adjusting handle contacts power beyond hose on L6060
   / Help! Three point hitch adjusting handle contacts power beyond hose on L6060
I spoke to my dealer who suggested I might just unbolt the power beyond harness and wire tie things up. I tried to cheat and just wire tie it up but the wire ties would not pull the hose back enough. I think long term that bracket that holds the coupler is going to have to be modified to move the coupler over to the side away from the center of the tractor more. I have to say I am very impressed with the tractor, but when it comes to having the backhoe option, it just becomes a real pain in the butt. It's a good thing I needed a backhoe.
   / Help! Three point hitch adjusting handle contacts power beyond hose on L6060 #12
So the thing is, this is on the power beyond. So it's not just one cylinder that is on this hose. Everything goes through it I thought.
Ah.
Looking at your other pictures, I would put a small pipe wrench or a large crescent wrench on the bracket to bend it toward the outside a little.
Aaron Z
   / Help! Three point hitch adjusting handle contacts power beyond hose on L6060 #13
Looking at the bracket that holds the PB, can you unbolt it and rebolt it on from the outside of the orange metal piece rather than on the inside as it is now? That would move it out the same distance as that orange metal thickness. Otherwise I would add a 90* fitting as suggested. You could use a larger 90* fitting, and then a reducer to connect your hose (if the same size 90* restricts too much flow).
   / Help! Three point hitch adjusting handle contacts power beyond hose on L6060 #14
Good point, that might gain the OP enough space.
I suspect that a 90 wont hurt anything, IIRC Deere uses them on most of their machines with a removable backhoe, but time will tell.
Aaron Z
2014 Dodge 5500 4X4 Bucket Truck (A55302)
2014 Dodge 5500...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
294 (A52706)
294 (A52706)
2022 CATERPILLAR 301.5 EXCAVATOR (A52709)
2022 CATERPILLAR...
2009 International Workstar 7500 T/A Terex Commander C5045 Digger Derrick Truck (A55973)
2009 International...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
