HELP weak pump or worn lift cylinder?
   / HELP weak pump or worn lift cylinder? #71
It's good you're moving ahead and it may be something as simple as a lift cylinder seal but I'm betting on a valve issue. If it is a position control or relief valve issue, I will bet it is something simple like I have experienced ( small piece of debris letting fluid bypass). If you end up taking them apart it's pretty easy and straight forward, just disassemble them slowly so any springs under tension don't fly out suddenly and pay close attention to orientation of the internal parts ( makes reassembly and end results much easier....no need to ask me how I know :thumbsup: )
I've learned to video ANY disassembly of something that I've never done before, and who knows maybe someone else will be able to use the video also. No pump test yet very busy shop. Had to help older uncle go to VA hospital today for hearing test so no progress on valve body or lift cylinder either.
I'm going to have to find a different hyd shop . Seem that they don't have time to test my pump. Wish they had told me this in the beginning.
2022 John Deere 410R Sprayer (A53342)
2022 John Deere...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
